- Posts
- 97
- Likes
- 11
korenje
·RegF, you obviously know a little about materials. Zirconium-dioxide is 50 times stronger than stainless steel A.316 (not just 4 times) - for compressive strenth 100 times harder. The difference is though in elasticity and brittleness. The second is measured by dropping a hammer on a sample and tells how many Joules is needed for a sample to break.
But the bigger problem than pure ZrO2 is sintered ZrO2 which could be porous or with impurities or with improper bonding of the material. Actually in sintering process the bonding of powder should evaporate as much as possible, but if some stays in the cheramic it will work as "adhesive" bond wish is basically not wanted. Especially if it's in planar shape.
