Speedmaster Caliber 321 Bracelet on 60th Anniversary Trilogy Speedmaster?
Looks great. Do you changed the endlinks?
Best Alex
No, but it is sitting a bit lower as you can see in my 3nd photo.
Thanks for the reply. If everything is tight enough I am absolutely fine it. I am looking forward to the first pictures with the Seamaster
The eagle has landed! I am so pleased with how this turned out. This is really what the 60th should have come with originally. The 1.8mm spring bars don’t quite fit though, I can only get one side to click in. I have a set of 1.5mm thin bars on order and hopefully that does the trick.
Looks great,
but the clasp thickness is as ugly as the original trilogy bracelet clasp was…:whipped:
BR
Hans
[[/QUOTE
Oops,sorry about that! What I meant to ask was.does anyone know what size screwdriver is required to size the bracelet?
I've used 1.5mm with a fat blade.
Collected a 321 bracelet today from my local boutique,i only waited one week for it to arrive.looks great.
But previous posts are correct about the 1.8mm springbars are not a good fit.does anyone have the part number for the slimmer 1.5mm ones?
I would like to get the same bracelet, let me know if the 1.5mm spring bar works.
Your bump reminded me ...
I did went ahead and ordered one for my 60th. It looks great despite having a bit of gap on the top.
I have no problem ordering from my AD and it arrived in just a few weeks. I will taking this over the 80k one!
I know the top of the endlink isn't level with the case, but is there any play or a loose fit as suggested?
The amount of omega bracelets can be overwhelming
With the 1.5mm spring bars the fit is nice and snug. The level difference across the end link and lugs is there but it's not something I notice on the wrist. My Speedmaster 3592.50 with 1479 bracelet also has a level difference across lug and end link and it doesn't bother me.
Thank you for sharing this. My father loves his 60th anniversary Speedmaster. I'm considering doing the same. Does your new tapered bracelet wear or feel any different than the one that came with the original kit?
Looks great and feels great.no looseness in connection to the case.do use 1.5mm pins.the only thing I miss is the slide extender in the original clasp.
I like the extender as well. Was surprised how often I found myself using it.
Well the new 57 Speedmasters comes with the 2.3mm comfort release like the Chronoscope, there is a possibility it will fit the 321 bracelet.
No. It is a good fit.
It is definitely less bulky and looks a lot better.
You will lose the on the fly clasp adjustment but I would say it is worth the trade off.
