Forstner bands relaunched
Pressure will be created by the weight of the watch itself anyway, put your arm down along your body you can see how much tension is made.
I don't have the NTTD in hands but I guess it could get the same kind of wear, metal against metal friction will always do that.
One of the solution could be to have a softer material in between the two to take the damage, like a thin rubber layer that will have to be replaced from time to time. It has been discussed about the JB on here, people tried small o rings but then you have to deal with cosmetic change as they are visible.
Thinking the same thing. If there was a small buffer or if the end links were made softer.
My guess is the original JB was designed with springed endlinks so it could be swapped out with ease (rather than using a watch tool or taking it to a watchmaker? Part of the patent? That they had no idea of the long term wear on lugs problem. Is this correct?
So why not redesign and better Forstner with endlinks that use spring bars?
My question is why does this happen if the bracelet maxes out at 20mm. There should be no spring action to hit against the lugs
It was made more for as a generic bracelet. The spring loaded system was designed to fit a wide quantity of watches despite the different lug sizes with a single bracelet. The JB was not made for the speedmaster.
It has nothing to do with the spring pressure, it's the rotation of the endlink around the springbar, you could have a fixed 18mm tubular endlink on the speedmaster, wear will still be created
Even wearing an OEM bracelet, wear on the lugs will start showing, even underneath the lugs and not just in between.
The tighter you wear the bracelet the sooner the wear will show. This is inevitable. Stainless steel is not as hard as one might think.
Wear and enjoy the watch and stop worrying is what I say. ... 😀
ah ok makes sense cheers for that...
Has anyone tried the flat link on the 3861 Speedy yet?
No but it will fit the same, or are you asking for photos. I'm tempted.
It would be expensive for me though because I would buy a bergeon 7825 to remove the bracelet unless I ask my AD.
Also I'd need to buy from Forstner
Forstner has a wide variant of the mesh bracelet. The thread is pretty long - I tried to skim through but found nothing about it.
Any experience with the wide bracelet? Pictures? The critics don't like the "Lolipop"-Look - does the wider bracelet help with this?
Definitely avoids the "lollipop" look, for folks who don't like that. Below's a photo of the wide version on the Speedy pro. You'll notice that the mesh/end piece essentially matches the lug width. It's surprising how much difference 2mm makes.
Did someone try to insert small O-Rings between the end pieces and the lugs to prevent scratching?
I ordered something similar to this:
https://www.amazon.de/gp/produ…tle_o00_s00?ie=UTF8&psc=1
The endpiece is spring loaded so it should be possible to insert the o-rings between lug and end piece. Or am I wrong here? Does it look terrible?
https://omegaforums.net/threads/o-rings-for-jb-champion.31214/
It does show quite a bit indeed
another one here
https://omegaforums.net/threads/jb-champion-and-speedmaster-fit-updates.16108/page-2#post-805021
It's on. Just got it with the bergeon tool. I was able to avoid all scratches that I could tell. Was not too bad to remove the bracelet on the 3861
Thats not the flat link, but congrats for the watch !
Wasn't sure where to post this and couldn't find it definitively on the site. Can someone confirm what size those micro screwdrivers are? Is it 1.4mm? The screw size seems close to my other omega bracelet and I'd like to get a quality one (Bergeon or similar).
For the flat link? 1.5mm.
