Beware: Problem Longines watches
I'm wondering how blind must one be to believe this shit?
but it's written on the dial: Glashütte original! 😉
Below are different images of the same watch/movement, with the visible dial foot highlighted. Dial feet are prongs, which are on the back of the dial, that insert into holes in the movement for purposes of situation. Since most Longines of this era had dials that were primarily composed of copper (I need to confirm the specifics here), the dial feet should appear copper toned. A white dial foot is usually the sign of a redial. However, not all redials present white dial feet.
or aluminum could be aluminum
ulackfocus has a thread here about Longines vintage automatic watches where he has a few pics with the correct factory fonts used.
I took that image and put it on top of the one we discuss about and tried to scale it (see image)
As you notice, first there is no vertical line above the stars. The fonts look OK, however the "s" is narrower than the original and has a space in the loop. The "p" looks also different. The stars look a bit bigger and are placed higher.
IMHO: redial.
Perhaps ulackfocus would chime in with his expertise and give us his opinion.
cleaned not redialed they look cleaned (dodgy lume dots) but generally ok..
they have been high before.. and that watch looks like it needs a crystal ring..
HIGH
8fa45245-b148-4ddc-854f-8341422b80d3
Jim Morrison HIGH
Longines dials of the 1930s and 1940s were not made of aluminum.
Dirty Dozen 12.. im not saying that particular dial is 100% but dials were made of aluminium.. military watch man? particularly obvious example is the Lemania HS9 15cht its why so few of them are surviving in GOOD condition it burns through them.. dont see why Longines could not have experimented with aluminium. Same era
I don't doubt that dials were made of aluminum but this thread is about Longines. And Longines dials from the period that I outlined were not made of aluminum. The white/silver feet that you see on redials is from a silver (or some other material) plating on the original brass. Some dials from the early 1930s were also made of silver but these all have a particular style.
OK, I know that this is not a Longines, however I could not help myself posting it here as another example of bad redial
The seller claims that the dial is in perfect condition.🙄
All it's missing are some vertical lines running from 10 to 8, from 11 to 7, etc.
India classic
Experiments may have been conducted but such speculation is not useful for assessing the vast majority of watches (again I am only referring to Longines of the aforementioned period). These hypothetical pieces would not represent any sort of norms.
aluminium dial 30s longines
Blatantly obvious redial. This emblem was not seen on dials until the late 1940s.
This dial is from the 1950s.
i understand what you are saying but also consider how bloody unlikely it is that they did not use the dial that is ALREADY there..
aluminium
feefe34c-af80-4844-98da-5ebb469c7753
aluminium
right last one then im off..
found this on OF 😎
By posting the two dials above, and claiming that they are aluminum, you have lost all credibility on this matter. Below are the dial feet of both watches. And both dials are in fact made of brass as expected. You are simply inventing information to support your argument.
