Universal Geneve Watches On Ebay
Sadly, there are no shortcuts to finding great Polerouters. You just need to keep searching and the wider you cast your net and the more frequently you search, the more likely you are to find what you are looking for.
You are right to think that it's unlikely that a good example will crop up on eBay but you never know, so don't give up but also try instagram, dealers, classifieds etc etc
It helps to do your homework, so that you are able to seize the opportunity quickly when it arises. In your case, you need to know the potential references for a black dial De Luxe, what movement to expect, what the crown should look like, the likely price range etc
There is a marketplace on the Polerouter reference site where you can add a wanted listing, which might bear fruit.
Thanks for your help I really do appreciate it!
The ref I’ve seen that I like is a 10357/3. But there's so many I expect there’s a few variations of the combo I’d like!
I’ll put up a post on the UGpolerouter site and again thanks taking the time to help me!
hi guys,
Did anyone see this one on eBay?
https://www.ebay.co.uk/itm/universa...2349624.m46890.l49286&mkrid=710-127635-2958-0
Appeared to be a rose gold capped case, rather than yellow gold which we see far more frequently.
It also had the triangular lumed hands. I don't remember seeing those on a gold capped example before. Perhaps an H20214-4?
I didn't make any enquiries but it was difficult to see whether the case had any wear to the gold capping or whether the serial or reference numbers were on the case back. Obviously the dial was pretty shot and the crown very worn too.
So, an interesting example but condition very much against it.
If it sold for £357 then that seems very fair.
This above watch went up on the Bay in the past 24 hours for a nine day auction. Someone must have felt that it was worth a contact with the seller??
Anyway, it was ended at 14.32GMT.
G
It’s an interesting one, couldn’t see one matching that combination on the reference tables
And it's back.
https://www.ebay.co.uk/itm/125112346396?mkevt=1&mkpid=0&emsid=e11021.m43.l1120&mkcid=7&ch=osgood&euid=e3553adb3d3846898e2217eb9e8f4167&bu=42950600645&ut=RU&osub=-1~1&crd=20220122014342&segname=11021&sojTags=ch=ch,bu=bu,ut=ut,osub=osub,crd=crd,segname=segname,chnl=mkcid
I've given up counting how many times this one has been going round. I wonder if it will reach its real value this time or whether it will be shilled to buggery.
It sold. And fast. Ask was €6500 I believe. Rare birds these Universal Compax pocket chronos…! Mine is similar dial in a different 14k gold case. 😉 Dandywatchman on instagram also has a super example of this same reference.
+1. Unbelievable high quality
