Totally agree. "Correct" is necessary but not sufficient for "Original". This is the reason for much of my ambivalence about a swap.
Problem is, the engineer in me likes "Correct" better than "Incorrect" so I've not totally ruled out changing yet. Plus research=fun.
The next conundrum would be whether the Huguenin Freres (HF) hippo case back used for this serial number would have had internal perlage or been smooth as covered in this thread from 2016:
https://omegaforums.net/threads/case-back-research-69-speedmasters.39671/
Poster's findings/conclusions are consistent with what I saw looking at a number of 145.022-69 listings shown below (an admittedly informal survey!). Both finishes seen in watches before my serial number up to 30582747, then perlage for 30584xxx and later. HF seems to have supplied all of the 145.022-69 ST hippo case backs. SW backs take over in the 31xxxxxx+ range, apparently all with perlage.
Is there any definitive info on dates/serial#s associated with Omega's use of perlage v. smooth-finish inside 145.022-69 pre-moon case backs?
From what I've found, a perlage case back finish (TypeA) would be correct for my 2H70 30593xxx watch, but perhaps others have contradicting data.
26xxxxxx: Hippo back, HF hallmark, perlage (TypeA)
28425xxx: Hippo back, HF hallmark, perlage (TypeA)
28425837: Hippo back, HF hallmark, perlage (TypeA)
29xxxxxx: Hippo Back, HF hallmark, smooth (TypeB)
29112207: Hippo back, HF hallmark, smooth (TypeB)
29113231 Hippo back, HF hallmark, smooth (TypeB)
29114918: Hippo back, HF hallmark, smooth (TypeB)
29119xxx: Hippo back, HF hallmark, smooth (TypeB)
29609xxx: Hippo back, HF hallmark, smooth (TypeB)
30582747: Hippo back, HF hallmark, smooth (TypeB)
30584386: Hippo back, HF hallmark, perlage (TypeA)
30565408: Hippo back, HF hallmark, perlage( TypeA)
30586515: Hippo back, HF hallmark, perlage (TypeA)
30589960: Hippo back, HF hallmark, perlage (TypeA)
3058xxxx: Hippo back, HF hallmark, perlage (TypeA)
---- 30593461: subject watch -----
31008929 - Hippo back, HF hallmark, perlage (TypeA)
