Recommended Vintage OMEGA WATCHES (only) On EBAY (NOT for Inquiries)
Vintage Seamaster Jumbo Cal 752 Day-Date with concentric dial, nice sharp case, could be some patina to the dial but I think most of it is the crystal, not a bad piece overall
https://www.ebay.com/itm/155916524773
30 mins left on this one, very cheap thus far
This one goes off later today
Talked to the seller, bracelet should be good for ca. 18cm wrists! Just take this into account when you're bidding. Wouldn't be easy to find spare links.
Really nice Seamaster Cal 750 Sparkle Day-Date with clean dial and sharp case, needs service but 100% worth it
https://www.ebay.com/itm/176073244449
Quite clean and sharp Seamaster Sparkle dial Cal 750 36mm in stainless steel, throw the twist-o-flex in the bin and put it on a nice strap and have it serviced and that will be a beautiful watch
https://www.ebay.com/itm/256329780160
If you look at some angles as shown in the listing, there is some serious discoloration of the dial near the crown. A sure sign of water intrusion. The movement may have been repaired, but the dial likely cannot be cleaned without further damage. The hands are damaged as well.
Closer has a lot of vintage watches at good prices (especially given the current ¥ to $ exchange), but you need to be careful with them. Deliberately overexposed photographs hide a lot of flaws.
gatorcpa
