REBUS puzzles
Slightly obscure. Maybe enough to present at least a modicum of difficulty.
Or maybe not, knowing the calibre of the frequenters of this thread…
his first novel
a question in need of answering
A single word answer will suffice
Rosso Di Montalcini
Morellino Di Scansano
Vino Nobile Di Montepulciano
Brunello Di Montalcino
Capricci (a bit of a red herring, you can safely ignore)
Why....................................................n
(Wasn't hard to guess Matty, now if you were a motor mechanic or something it would have been harder).
correct
But not the answer
Looking for a much more specific answer…
correct
But not the answer
Thought it was too easy.
I sense Tuscan Reds, but Capricci confuses me.
Warmer for sure
these are mostly Tuscan, all red, all…
No, there is a mix of doc, docg and igt here
Let me remove the ringer, Capricci
I’ll go back and remove that- and it should be clearer
@Matty1
Just to clarify; Capricci Sangiovese is a blend. The others are a single grape wine. Is that why Capricci was removed?
I’ll drink a nice Chianti or a South-Eastern Australian Merlot, but I ain’t no wine buff.
@Matty1
chianti is typically a blend too, with at least 75% Sangiovese, (80% for Chianti Classico) but usually it will contain 10% canaiolo, sometimes Colorino, with other varietals allowed in the mix too…
all of the remaining clues were regions wherein the red wines must be a majority or in some instances 100% Sangiovese
Capricci, not being a region was a bit of a red herring, so I thought best to pull it
This’ll be an easy one (for somebody)!
Just hitting the sack, now that the Temple of Solomon has been destroyed…
I'll go for Guiseppe Verdi, composer of "The Chorus of the Hebrew Slaves".
Chorus of the Hebrew Slaves is also known as Va, pensiero.
I mighta got it by the next solar eclipse, but actuarial tables tell me I won’t be alive, then! Well done, James!
