Possible new 300m spotted on Daniel Craig
I'll say again, I think the size issue of the current Seamaster is overblown.
2254.50 SMP300
41mm x 12mm 158g LtL 47mm
Green SMP300
42mm x 14mm 198g LtL 50mm
Heavily rounded using inaccurate, but precise enough calipers.
2mm’s can make a world of difference when it comes to wristwatches.
The 2254.5 is 11.7mm.
It just makes me think of this these days, heh.
Felt inspired, and since I actually quite enjoyed making those renders the other day, here's one (probably) final one - my dream fifth gen Seamaster concept. Changes made to current fourth gen:
* Reduced HEV length. I don't think it should be removed because it's part of the model's identity, but it should be smaller like the earlier gens.
* Tapered the Bond bracelet, from 20 mm lug width to 18 mm at clasp. A 1 mm reduction per outermost link would be subtle but effective.
* Used the 60th anniversary first gen wave dial to clean it up, but kept the fourth gen red accent to keep it modern, and the date wheel to keep it competitive. But I'd like to see date and no date options, frankly. Also, kept the fourth gen low dome crystal. I love the big dome on the heritage models, but I don't think it's appropriate for modern references.
* Added an applied Omega logo, as per the current generation sapphire sandwich Speedmasters. Calls back to the second gen and third gen applied logos and elevates the dial a little to reflect the higher price points lately.
* Added a watermark after what happened last time, although the hype's probably passed already. Would not be on the final watch 😜
Also, it isn't reflected in the mockup but I would like to see a return to 40-41 mm case size, 47 mm lug to lug and 12-13 mm thickness. Ideally 12 mm, but I imagine they'd keep the sapphire exhibition caseback so a cap at 13 mm is probably more realistic.
This is excellent!
I’d wish for a mid-size version. Same case size as before at 36,25mm but with 19mm L2L and a tapered bracelet. Would probably make me a OWG
I agree with you 100% on all points!
If the watch looked like this and had the features you've described here, I would buy it 100%!
By the way, excellent work on the mockup!
I'm excited about this. It tells me Omega is moving in the right direction and/or listening.
But if I really wanted this watch… I'd just buy the 2500 pre-ceramic 41mm model 212.30.41.20.01.002.
To me, at least, 90% of what makes this newly-teased watch exciting is the fact that it has no date.
This for me, and I will like the final watch even more if it is a little thinner with a solid case back. Excellent work on the renders @Jackeys
Is there precedent for Omega teasing a watch on a bracelet that isn’t the one that ultimately gets used with the actual release?
I can’t help thinking this will end up being a limited or non-standard edition solely because it’s on the Milanese and I don’t see Omega scrapping the typical SMP bracelet that’s such a part of the modern diver’s DNA. Unless we’re meant to believe that one aspect of the forthcoming change is that there will be a standard option for the Milanese going forward…
Guess I’m just bracing for disappointment, though hoping I’m wrong.
I would be amazed if they got rid of the iconic bracelet in favour of the milanese, though I could see it being a standard option like rubber is now. I think the milanese, the high dome vintage style crystal, the aluminium bezel and the no date point to this being limited or special - they wouldn't put out the fifth gen Seamaster with so many divisive elements. We'll have to wait and see what the fifth gen looks like, but I would bet good money this isn't it.
Personally although I did mock it up as a dream watch, I don't think they'll go with the classic wave dial on the next gen. They're probably going to stick with a glossy ceramic dial, so I just hope the engraved waves are more subtle. I just really hope they make it sleeker and clean up the dial, everything else is a bonus.
This will be an unpopular opinion perhaps, but I don't think the current SMP300m is an "elegant" diver watch like the previous generations were.
With the new waves glossy dial, bigger size, bigger HEV, larger bezel numbers, larger hour hand and the saturated blue color, plus the rubber alternative strap, I see the current generation as a fun colorful summer watch. Unlike other famous divers, it doesn't fit well with more formal clothings, or at the office, it's a watch to be worn at the beach, at the sea, outdoors, under the sun.
If they make it smaller, thinner, come back to previous wave pattern etc, it loses this fun factor that sets it apart from other more serious/luxury looking divers (e.g. Seamaster 300, Tudor, Rolex... ). You might like it or not, prefer it or not, but it will be a very different watch.
If they make it's smaller, thinner, come back to previous wave pattern etc, it loses this fun factor that sets it apart from other more serious/luxury looking divers (e.g. Seamaster 300, Tudor, Rolex... ). You might like it or not, prefer it or not, but it will be a very different watch.
Fair take. The current generation is definitely less elegant and a bit more casual and fun, which is not necessarily a bad thing if that's what you like out of the model. I would just make the case that there is room in Omega's lineup to do both. In the 00's, you had the Professional for a sleeker, more elegant vibe and then you had the Planet Ocean for a more casual, fun vibe. Nothing exemplifies that dichotomy better than Casino Royale. Bond wore a PO on rubber while he was out in the field and on the beach, and then switched to an SMP on bracelet with a suit or tux to dine and play cards. The line seems to be blurred now.
For what it's worth though, the old SMPs dress down on rubber surprisingly well.
Any bets on whether the new no-date diver will bear the 8806 or 8912 movement? (Guessing they won’t issue a new one unless they’re adding spirate.)
I’m guessing same movement in the NTTD and Bond 60th.
I don't imagine it'll have Spirate. I think they'll debut that on the next generation Seamaster to maximise fanfare, I still think this is a limited edition of the current gen for reasons previously covered.
Well, we had great reasons for why the white Speedmaster would be a limited edition when Craig wore it... so who can say for certain.
2254.50 SMP300
Green SMP300
There's not just enough a difference to matter to me. Watches wear differently for everyone, but the "OMG, it's sooooo big!" is just ridiculous. It is heavier and that's what I feel the most. It wasn't a deal breaker by any means and it was overcome by using aftermarket bracelets. Still a bit top heavy, though. Now I wonder if the clear case back is what adds the bit of thickness. IIRC, the differences in the dimensions of the cal. 1120 vs 8800 weren't crazy, but I think the 8800 was heavier.
Totally agree.
Planet Ocean 75th is 14.2mm and very comfortable, as it hugs my wrist. The Speedmaster sits higher on my wrist.
It's how all those elements work together. For my wrist, the smaller case size and lug to lug more than compensated for the added width.
Summary, wait and see how it feels.
Edit: I had a 2254.50 and yes, it is very thin and comfortable. But comfort doesn't require thin.
8806. I’d bet a grand on it. Well vs the 8912 anyway. That likely wouldn’t even fit, particularly if the case turns out to be smaller than std.
Regarding the depth, Here is a pic Chuck Maddox took of the 14.5mm deep 2201.50 original PO vs the original SMP. The difference looks pretty marked to me, though it wouldn’t be so with a current SMP which has got a lot fatter. Note there have been 17mm deep POs too.
I wear thicker watches myself without a thought, but unless you’ve tried one don’t dismiss just how thin the first SMPs were, they disappear on the wrist. Sadly movement changes and display backs have consigned that to history.
Love this, really puts it into perspective. Wonder if there's any die hards on this forum with one SMP of each gen (Well, first third fourth) they could line up like that? Or even just a first/second and fourth? As the current SMP isn't quite as thick as the PO at 13.6 mm. Though closer to a first gen PO than a first gen SMP by far.
Google fu indicates:
First Gen SMP: 11.5 mm
Second Gen SMP: Unchanged?
Third Gen SMPc: 12.8 mm (+11%)
Fourth Gen SMD: 13.6 mm (+18%)
First Gen PO 42: 14.5 mm
Current Gen PO 43: 16.1 mm
I considered whipping something up in Photoshop, but Omega don't provide side profile shots other than a generic diagram, so you'd be approximating lug and crystal shapes or using iffy slightly different photos. Not as valuable as a photo.
EDIT: I found some references for the first gen that list it at 11.7 mm or 12 mm, but I measured mine with calipers and it corroborated the 11.5 mm source.
Wow, this is quite instructive to see in bare numbers. Hadn't appreciated that the PO had got quite so thick. Makes me think, my first Omega was an original 45mm PO and I didn't give it a moments thought 20 years ago as to whether it was too big / how thick etc. Funny how I would now be reluctant to look at anything over 41/42mm diameter, ideally less, and I'm so much more aware of how a watch fits and looks on the wrist.
Your wish is my...
I'm no Chuck so my effort it a tad more amateurish. I've owned all of them at some point but only have 1,3 and 4 (current) at present. The missing Gen 2 was thicker than Gen1 due in part to the 2500 movement but also the relief in the caseback, around a mm thicker in fact which is one reason why I am less keen on that than the Gen 1. I can forgive that more in the Gen 3 as you gain the ceramic bezel and a high level of finishing.
And Gen 1 vs the current standard model. Who ate all the pies?
Thanks, great work! I thought the second gen was the same thickness for some reason, but it looks like you're right, they increased by 1 mm to accommodate the coaxial. I also found the third party number for the third gen didn't match Omega's website, they list the thickness themselves for the ceramic models.
So the updated thickness numbers and percentage gain over first gen:
Second Gen SMP: 12.5 mm (+8.7%)
Third Gen SMPc: 13.1 mm (+13.9% or 4.8% over second gen)
Fourth Gen SMD: 13.6 mm (+18.3% or 3.8% over third gen)
I assume the second gen thickness increase was entirely due to the co-axial escapement, and the fourth gen's increase is probably due to the sapphire caseback and in house movement. And it actually had the smallest increase of any generation! But what was the third gen's excuse, I wonder...
Anyway, I still hope the next gen can shrink down to under 13 mm with a date function.
