destroid
路MWO has the original bezel diameter as 38.6 mm and the reedition as 39.7.
I don't know if the new bezel can be used as a direct replacement but it can be made to fit with some modifications.
Interesting.... I asked my watch maker to fit such a bezel on my 105002 and he told me he hasn't succeed, the bezel was too large (inner diamteter). What kind of "modifications" have you done MSNWatch ?
@Spacefruit : you had fitted a replacement directly on a 2915 without modif ? Do you have pictures ?
I am currently looking for a substitution to an original bezel on a 2915, I'm very interested in a solution.
Or maybe someone has a Base1000 bezel in stock.... ????
Or may be I should just check another watchmaker....
Best
Outer diameter is different. Inner is the same.
but the bezel can be modified to fit.
And how would you do that? Cause i pr茅sum茅 that the inn茅r diameter of the old one is smaller than the replacement one...
Actually that does not fit my research and observations.
I have found that Omega did indeed fit several executions of caseback to the 2915.
The very first caseback, fitted to the 2915-1, with speedmaster around the edge, does not appear to have ever had a Hippocampus etched into it at any time. All subsequent ones do show, to some extent or another, a Hippocampus.
Source: Personal Observations, and subsequently MWO page p150
