Learn How To Fish
Hi guys, I’m new to this. Whats the thoughts on this watch and website?
https://watchvintage.co.uk/products...-ville-crosshair-sunburst-cal-601-ref-135-010
Hi lloydm,
I have bought From this dealer before (within the last few weeks, bought a pie pan ref 14900.)
He was absolutely professional and the watch was better than expected. He fully services everything before selling his watches which is nice. He also sends an invoice link which gives you the option to pay by bank transfer or credit card which I thought was nice as I like to pay by credit card where I can for extra buyer protection.
Can’t recommend him enough. His name is Scott and he’s very responsive via WhatsApp.
Wouldn’t hesitate 👍🏻
He may be very responsive but he’s also very expensive 🤔
Newbie here!
Does this dial look off to anyone? Can't find another example of 136.0049 with this dial online. Also the hands look incorrect?
And it looks fine 👍
Really informative for new vintage collectors. This should be a mandatory read before purchase. It would have saved me a ton of money.
Hey, does this big crown 166.062 look alright, questioning if it looks too crispy?
Edit never mind, it is indeed a re-dial
Might be better, as a general idea, if you start a new thread to make any enquiry about a watch
Hi, great catch, but may I ask you which features/photo make you confirm redial? I would like to learn from this... Thanks, Szabolcs
Hi! Thanks for this thread. I'm new to the forum but have wanted a vintage seamaster forever. Hoping to make the leap soon!
2.1. You may love patina, but for a lot of people it is still damage/decay so unless it's a special case, a patinated dial will lower the value of a given watch. As this subject is very, eh, subjective and a case of what one finds attractive take these points as mere guidelines.
Patina should be even on a dial. No matter if it's light spotting or the orangey-brown film of tobacco smoke residue from a long period of exposure to that particular element, you do not want random blotches on the dial, but instead an even spread. If the dial damage in question is pronounced at 3 o’clock on the dial there’s a good chance that the cause of the damage is a leakage around the crown, letting in moisture to the case.
Two cases of heavy dial patina, probably from tobacco smoke exposure*. Note that the bottom one is next to a very similarly dialled Seamaster that's also patinated, in this case more light and mostly in the middle of the dial:
(yes, they both were the same light colour to begin with!)
As "patina" could just as well be called "damage", this raises another issue - how about the movement? If you find a heavily patinated watch to your liking, you must inspect the movement. Chances are that whatever caused the damage on the dial side has affected the movement too. Funnily enough, the word “patina” is rarely used on damage below deck...
In the case of black dials, there are several ways for these to age. Have a look in the "Vintage Black Dials Only!" thread, where I have found some of the following examples:
Black fading to grey:
Link
Link
In both cases the black colour is slowly losing its lustre and turning slightly grey. The text changes too and will, typically end up like the "Seamaster" text on the upper model and be hard to read.
Just like this:
Link
A pretty common variety of patina on a black dial is the "gold speck" dial, or the "starry night", where a number of golden stars dot the dial:
Link
This is due to the way the dial is produced: a layer of black paint is added to the brass dial, letting the brass appear where there is text. Eventually, the paint starts to flake and the brass peeks through. Simple.
Probably the most widely liked type of patination of a dial are of the "chocolate" or "tropical" variety. It is my understanding that to begin with, the "tropic" moniker would only be used on a black dial turned lighter brown, but now I seem to see it all over the place. Oh well. As mentioned, patina is a subjective thing and you'll have to make up your own mind whether or not you like it, and if you like it enough to pay a premium over a ordinary specimen. Most brown dials are due to paint defects and the effect of UV and/or moisture ingress.
Link
Link
Quite a few blue dials - often those with a metallic finish - have also been known to change appearances. Here's a member's Omega Seamaster 176.007, which was a striking electric blue when it was new:
Link
The reason why I've focussed so much on black dials is that when these 50's and 60's watches were new, black dials weren't in vogue for a number of reasons. Black dial Constellations, apparently, were even a special order item. This means that there are many fewer of them - and due to the popularity of today, redialers will often paint their creations black! So if you are assessing a piece online and the black dial looks too good to be true (most have deterioated to some extent), then it most likely is. Tread very carefully.
*EDIT: I have now, some time after writing this post, come to the conclusion that correlating this particular type of dial aging with tobacco smoke ingress is probably false. It seems to be more likely to be a manufacturing defect in the lacquer, seeing that it often occurs in the same references and isn't spread evenly across several different refs.
great write up
Hi Guys,
looking at possibly adding this gold capped 167.005 to my collection. May I quickly check if the dial is original and not redialed?
Thanks in advance!
Hi Guys,
Thanks in advance!
Best to start a new thread for your enquiry 😉
