Information on my Seamaster cosmic 2000+ watchmaker in Melbourne
B
I wouldn't worry too much about the plating. Even if you can get a brushed finish back without losing too much material it will, over time get wear spots and lose that "just new" look.
It's a well worn vintage watch. Let it live out its days as your grandfather saw it.
This model is a bit different to the run of the mill Omega. The movement case is a sealed can where the movement is accessed after the crystal is removed by air pressure. This "can" is held inside the middle case by a gasket. You need a watchmaker familiar with this model and one with an Omega parts account in case spare parts are needed.
I was going to recommend a watchmaker, but his workload is currently 20 weeks and counting so if you need to do it maybe check in the CBD.
Appreciate it a tonne! I am tossing and turning about what I will do with this sentimental piece..... I'm feeling the 'leave it and enjoy it' type of mentality. I have been wearing it lately, and its still so lovely and doesn't look nearly 50 years old.
Interesting! are other omegas a remove the back of the casing type job? How deep is the waterproofing on this model, and generally how long will the movement retain time if not worn? I have seen it to last anywhere from 12-24 hours without being worn.
B
If it was my memento I'd just get the movement serviced and the watch cleaned and new spring bars for the bracelet.
The watch is only as waterproof as its last service and proof test. If it hasn't been serviced in the last five years it's not waterproof, and possibly not water resistant.
The caliber 1012 in good condition should have a power reserve of 48H minimum from fully wound.
Its fully serviced, all gaskets replaced I believe.
I read online its supposed to have 60m depth of waterproofing? Doesnt bother me as long as it doesnt care if its submerged
When you say fully wound, youre referring to me actually winding it before wearing? I just put it on and with a few shakes it starts up again.
If it was fully serviced then all gaskets should have been replaced and you should have received an invoice detailing the work done, and ideally, a timing machine print and a waterproof test results print out or form.
If you don't have the waterproof check stuff it's not waterproof.
Most automatic watches will spring into life after a few wiggles, but to achieve full power reserve it either needs to be on a watch winder at the correct settings for at least overnight, or manually wound until the mainspring is tight (it won't break if you keep winding). Usually between 40 or 50 "winds" with your fingers is enough.
