Just wauw...
That is a WORLD-CLASS example! 🥰
Ugh after a 4 day weekend it’s back to the grind.
Countdown to next 4 day weekend towards the end of December starts now!
When the light hits your watch just right. Personally, I like overcast weather for watch pictures.
Gruen Techni-Quadron with the new-fangled Guildite (SS) case, style 168.
Blued hands👍
Circa 1934
15j 877S movement
Period shark strap and buckle.
Unitas chronograph, Venus 210 movement, approximate size 35mm diameter, 41mm lug-to-lug
You know it...Dunkin’ hats... 👍
I got all that maximum weight chart figured out (assuming that ZFW means "zero fuel weight") except for that silly "taxi weight" which is a mere 500 lbs. more than the "takeoff weight." In the overall scheme of things, "things" being 83 tons of loaded airplane, what difference could the 500 lbs. truly make?
The difference it makes is likely the reason I'm not flying the skies and you are, even if "Fate Is the Hunter" by Ernest Gann is one of my very favorite books. http://www.bookrags.com/studyguide-fate-is-the-hunter/#gsc.tab=0
