What reference(s) should I consider?
Hi all,
Although I started my Omega journey with a vintage piece (135.011 SM600), I've ended up more on the modern side since then.
But I'm beginning to contemplate picking up a vintage piece---the issue is, I don't know which one, and I know better than to stumble blindly through sales listings. So I thought I might list some criteria, and see if the hive-wisdom here might point me to something.
What I'm after:
A dress watch
Rose (or pink or red) gold; yellow gold isn't at all out of the question, but it's less desirable
35mm or bigger (excl crown); this may prove the most limiting factor; I'm open to 34s that "wear bigger"... maybe
No radium (else I'd have snatched up that gorgeous Cyma that's for sale, weeks ago)
No date, preferably; no complication at all is great--but open to small seconds or moonphase
White/opaline/silver dial, the simpler/cleaner the better
I'm willing to consider various hand-styles and indices, though I don't like Romans or arrowheads, generally.
Omega is my first choice (of course), but I'm also receptive to suggestions from other brands.
Hoping to keep this under $3500 USD, which I don't think should be too hard.
Any suggestions?
Thanks in any case!
Including a pic of a JLC I really like, if it helps to trigger anything. (It's about twice what I'm looking to spend, though.)
With that budget you should be able to get a very good example from almost all manufacturers except the very high end ones (Patek, Vacheron etc).
If you are not stuck with a brand or a model I would just broaden the search and look what 35mm 18k gold dress watches you can find in very good condition, there are loads of high quality brands in the 1000-1500USD price range.
This for example is a Movado of mine in 18k yellow gold, full set sold 1960. Thin, elegant, no lume, no date and all other elements I want in a dress watch.
IWC ( fancy lugs ) made some nice ones in the 50s and 60`s, and all in 35 and 36mm, it is a great era to choose from !
Classic solid gold Longines watches, cased by Longines, can feature appealing hues, both in yellow and rose gold. This 18kt rose gold Longines dates to 1948-49 and features their 27M movement.
Those IWC ( fancy lugs ) from the 50s and 60`s, really are beautiful. They were a great era for watches !
Nobody suggested good old fashioned Connie, maybe deluxe dial? 😉
Is there any good ones for under 3500USD let me know 🙄
Maybe not pie pan but gold dial 14381 can be found within price range 😁
I certainly wouldn’t be letting mine go anytime soon for that kind of dosh.
The Omega cursive Genève's can still be found within your preferred price range, like my 2903 from 1958. With a slim bezel, heavy hour markers, pie pan dial and double-crosshairs, these definitely wear bigger than the 34.5mm case diameter would suggest...
...my wrist is about 7.25 inches diameter...
Good luck with your hunt!
I'd second the choice of a cursive Geneve. Lovely watches. They aren't that easy to find in good condition but are worth the hunt. They also do not have radium which is another of your criteria. Here's mine from 1959:
