DLT222
路路Double D @ 惟FYes its the 42mm..
You mean the protective cover? If thats what you mean then no.
Al, I have the .pdf file on the updates / repairs to the 330x calibers.
I'm in the mattress industry and there are "life tests" for beds too. If that product can have sufficient R & D to know that their failure rates are extremely low, why couldn't a watch company? Granted, the cheap beds don't go through this kind of testing, but to continue the analogy Omega doesn't make cheap watches. I understand that there will be warranty issues once in a while, but from what I've seen on watch forums the caliber 2500 A, B, and C had the highest number of complaints by far of any $2000+ watch.
Not sure what your point is with the 3301 tech guide and documentation?
I guess you are assuming the failure rate for the 2500 A, B, and C is not "extremely low" so I guess I have to ask the following:
1 - What is your definition of "extremely low"?
2 - What is the failure rate of the 2500 A, B, and C?
3 - How does this compare to other watch movements?
Although the designs do have issues (most watch movement designs are a series of compromises after all), I would hesitate to draw any sound conclusions from anecdotal evidence posted on watch forums. If you know the actual failure rate, and know the modes of failure so we can narrow down what is co-axial related and what's not, then we can have a real discussion. Otherwise it's pretty much speculation.
Is it frustrating for the owners? Yes of course. Is it bad publicity for Omega? Yes in some respects, at least on watch forums, but I don't see their sales plummeting as a result. Does it mean that every watch that is not a 2500D will have problems? No certainly not. Does it mean that watches that are not a 2 level co-axial will not have problems? Of course not.
I guess what I'm saying is that we really don't know how much of a problem these are, and how these problems compare to other problems on other watches. Until you perform some sort of fact based analysis on the rate and modes of failure, then you are making a lot of assumptions about the 2500 early versions that may not be anywhere near true.
I'll again concede to speculation, but reiterate that when you hear it not only from forums but also from watchmakers who work in Omega ADs then there's gotta at least be something to it.
Oh....very very nice catch................blue over white works beautifully. Very charming.
Congrats.......
Yes, expensive ...and also I'm not sure thats its a 42mm model because the blue tick to the right of the date is smaller than my 42mm and watch looks more like a 39mm
It says 2010 model so maybe it has a different dial than earlier models?
It seems a lot of people call the 39mm version as a 42mm version.
I'm 99% certain that its a 39mm version because the bracelet also looks like the 20mm version and not the 21mm version as used on the 42mm case. The 20mm bracelet uses end links 898 (marked centrally) and the 21mm bracelet uses 897 (marked at the side)
