guppydriver
·I'm looking at ordering a gray dial. I will probably spend most of its time mated to a bluen rubber strap, but I think I'm going to order it on the bracelet because the gray dial can dress up IMO a little better than the other versions and because it's obviously cheaper to add a strap than a bracelet post purchase.
Two questions:
1. How much is the actual OEM rubber strap from a AD or OB at retail? I know they occasionally surface on Ebay and what not, but I'll probably take the easy road. I watch Youtube videos, and frequently hear "several hundred" dollars, but can't find an actual list price anywhere. Is several hundred $300, $400, $600? Will an AD typically take a few bucks off?
2. Is the Zealande commensurate in quality and is it worthing saving some money over the OEM? If the Zealande was a $100 or so, I think I would order right this second, but it's now up to $175. At this price, is it worth going up to the OEM (Which is why question 1... I don't know the delta between the two) or is the quality of the Zealande sufficient to mitigate having to be gouged by the OEM version.
Thanks so much!
Two questions:
Thanks so much!
