Strong auction result for Constellation
I don’t think this connie has sold. I was following it since the beginning and the seller seems shady.
It ended at 2200 bucks but it now displays 1yen. This usually entails the seller has cancelled the sale.
I was just going to write the same thing. Annoying behavior. Well, if he wants 3k+ for it we might see this around for quite a while.
True. I watched the auction end, but apparently he canceled it retroactively. Well, he can hold onto it for a while and maybe the market will rise. 🙄
It does, for exceptional pieces, so if he found a very good case for the dial (or has the case restored well) this might actually scratch on the 3k mark. But I doubt that’ll happen.
That’s crazy. The dial even has some slight spotting visible in that last photo.
The final price doesn’t make sense to me.
I was outbid by a very healthy margin on this one, so I agree. That said, we don’t see these very often so not a lot of reference material to draw from.
Reviving the thread sooner that I anticipated:
https://www.ebay.de/itm/25561746048...JxnDeyNRhm&var=&widget_ver=artemis&media=COPY
The only 3 pics from the ad:
This one’s just finished at >3500$. 2887 probably, so yes, uncommon reference and the lume plots on the arrowhead indices are special order. Still. I wonder if we’ll see it around soon. The final price doesn’t make sense to me.
Was also watching that one and could not figure out the exact reference, was first thinking a 2652 since the screwed caseback but the piepan dial did not make sense to that reference so I suspected the more uncommon 2887 reference.
The price don't make sense to me either but I also have never looked at the 2887s, but the rarity probably justifies the premium.
There will be varying opinions on that. Personally, I don’t see why it should - after all, it’s so similar to 2852s (let alone the caseback) that it doesn’t justify a 1500$ premium in my book. Auction results from the past seem to confirm this, I’ve never seen one go for that amount anyway.
@TexOmega went through a similar thought process a few years back but the watch actually ended up being a 14381. Would be interesting to open this one up and take a look. You can see that thread here: https://omegaforums.net/threads/unknown-constellation-surfaces.61120/
Can you post previous auction results for these lumed arrowhead pie pans? Would be good to have some figures for the record.
I was referring to 2887s, not 2887s with lumed arrowhead pie pans. It’s a double limitation that’s quite significant. Also, admittedly, I haven’t followed any Constellations with this particularly odd lume configuration as I find it rather hard to look at. 😁
Ah, I see. As minor (and controversial) as some bits of lume might be, we know this silly hobby is one where those minor details can make or break the bank. Would be interesting to compare to other examples, if they exist. And if they don’t, maybe a $1500 premium isn’t so bad after all for the right collector.
A 14381 wouldn’t have ‘Constellation’ printed on the case back.
So most likely a 2887 as noted above.
Maybe. However, that was not the case (pun not intended) for @TexOmega in the linked thread above. I encourage you to click on it and give it a read as it’s the most similar example to the watch on eBay.
Let’s compare casebacks from the eBay watch (pic 1) to @TexOmega ’s 14381 (pic 2) to a 2887 (pic 3):
I had seen the previous thread ( some time ago)
But I stand corrected. - thx for reminding me.
It will be interesting to see if these "rare event" auctions will have a broader aura effect. These results will inevitably cause people to jack up the asking prices of more common references.
Certainly doesn’t help how much some visible dealers are asking for, either…
I think that many dealers do follow auctions, and routinely set their prices to be 50-100% higher. I recall that after a certain well-publicized major auction, several well-known dealers immediately jacked their prices up on several models.
Looks like Omega Enthusiast won the auction for the lumed arrowhead Connie that went for $3500 (watch on the left in pic below). It’ll be interesting to see if he sells it and, if so, for what price.
