Recommended Vintage OMEGA WATCHES (only) On EBAY (NOT for Inquiries)
What is the main difference between Geneve and a. Seamaster
Different models, the Geneve is a more entry level model line with simpler case designs but some Geneve cases were also used by Seamasters
Thank you trying to get my first vintage without breaking the bank.
Decent wearable stainless steel Geneve Calibre 1012 automatic going off in 40 mins, currently $220
$305 was the winning bid. There are some real bargains to be had.
Ya I missed it by 5 dollars
You forgot Michelle Obama's mantra, “When they go low, we go high”. If you’d bid an extra $50 on your original bid, you’d have got the watch AND saved $45 😁
This one goes off again in 10 hours at a lower price, needs a Cal 1345 quartz movement but cheap donors aren’t hard to find, 14K solid gold piepan in really nice condition
https://www.ebay.com/itm/354703432854
This one is interesting, 18K gold French case Geneve with Cal 565 full rotor automatic, should clean up decently and make for a good daily wearer.
https://www.ebay.com/itm/295638056394
Nice 18K solid gold Constellation linen dial, polished but not excessively for an 18k piece to wear, these have gone for around $1800-2100 recently so the starting bid is under value.
https://www.ebay.com/itm/295639195282
Bid placed.
Bid placed.
Auction closes in 9 days, you're better off following it and bidding in the last minutes if the price looks right to you
This is quite nice indeed, Calibre 552 Seamaster with one of the unique vertical deep brushed texture dials
https://www.ebay.com/itm/185859795612
Very unique dial and makes a great dress watch. Will make a bid closer to end 😀
This is a nice little cheapo, Geneve with unsigned dial in steel, good condition overall with OEM bracelet Cal 1020/1022 going off in 15 hours for $300 opening bid
https://www.ebay.com/itm/394563237555
