BlackTalon
··This Space for RentThe issue isn't whether or not you are worried about your watch, or a warranty claim. It is about posting pressure-related information that simply is not true.
Al, all I can say is good luck when you take the watch back to the AD when it has leaked, and how much credence will they have when they say a guy on the internet said it would be fine, not much I'll wager.
How deep is your bathtub/ kitchen sink? I can't imagine there would be more than one foot of water depth in either, and likely a watch would not be submerged more than a couple inches.
A compromised seal is a compromised seal. Moisture vapor from the air is just as likely to bypass a compromised seal as actual water drops. A bad seal will let moisture into the watch no matter what.
All that being said, I do not usually keep my Speedmaster on when I give my son a bath, and I sometimes take it off when I was dishes. But that is because I have a leather strap on it.
I never understood why anyone would shower wearing a watch. The watch will remain wet long after one has dried off. Makes no sense to me.
Again if you choose not to, that’s fine. But the fact is if properly maintained the watch is fine up to 50 m depth. It was designed to take that much pressure, and knowing how these things are done there’s most certainly a safety factor included in that design. It’s not me that gave the watch this rating, it was Omega.
Trust me I deal with flooded watches on a regular basis, (one came in last week in fact) and the reason they leak is nearly 100% due to lack of maintenance, or some type of damage to the watch. It’s never because a fully maintained watch has been subjected to “too much” pressure.
...plus you are inadvertently shooting water from the shower head onto the watch head which will be of a lot higher pressure than dipping it three feet in a swimming pool. That is why it is never recommended to take a watch into a hot tub spa where there is hot water and pulsating water jets. Most likely it will be fine but I just don't chance it.
Do we have to start over from the beginning again?
Funnily enough, the opposite is true. I've read several posts from people who had their watches repaired under warranty due to water ingress - Omega themselves rate the watch to 50m WR and that's where it is at.
If you develop the habit of not caring about water and moisture you will be fine, for a time. Most people then simply forget when they exactly bought the thing, when it was last maintained, and problems occur inevitably after some time.
Or rings, for that matter. If I even leave just my wedding ring on for any length of time after getting my hands wet, I get that white macerated skin ring under it almost immediately. As for the Speedy, I've worn it reffing hockey games when the scoreboard was out and, sometimes, under my glove while practicing (alone); but I don't even expose it to rain, let alone ever submerge it under water.
This is why the guy that confidently says he'll be wearing his PO to the beach, and thinks that because it's "made from the ground up" to be water resistant it doesn't need regular testing or seal replacements, is the guy most likely to have a flooded watch.
There's one O-ring in the crown of a Speedmaster, and one O-ring in the crown of a PO. If that O-ring fails, it makes no difference what the depth rating of the watch is...
Any chance you can point to where I mentioned that my PO won't need regular service attention?
I wasn't referring to you in particular - I don't know how you treat your watches and it's no concern of mine either way. You have your mind made up, so my comments are for those who still want to understand water resistance and deal with facts.
I wasn't referring to anyone "in particular" but the general notion that people have regarding dive watches - something I've stated many times before. The wording you used in your posts is indicative of that sort of mentality, but again not knowing anything about how you service your watches, it's clear I can't know that you specifically would or would not do as you have pointed out.
