Planet ocean 39.5mm or 43.5mm
Omega did have to make some changes to the movement to thin it up. In exchange for that, you get the first Planet Ocean with a rational case height since the original 2500 series. I think it's a very good move by Omega. I also like the OEM waterproof leather strap that comes with some versions of this watch.
I would love an answer to this question: " Any drawbacks the 8800 movement than the 8900? I do know that one barrel does not even out the power as two do? Also I heard the 8800 movement has ball bearings and the 8900 does not? Thanks
I'm not sure exactly what you're looking for. My 8800 hasn't shown any appreciable isochronal error that I can see. It appears to run a pretty consistent 3 sec/day fast, right down the middle of Omega's METAS spec for the watch, regardless of how fully it is wound. So one mainspring doesn't seem to be a disadvantage in my experience. I guess it might be if that 5h of power reserve really matters to you ("only" 55h vs. 60h for the 8900). The other mechanical differences have already been discussed in this thread.
Thanks so much I just wanted to put the rumors to bed that a double barrel is much better to have.
Watch movements are an almost endless series of compromises, so asking if two barrels are better than one in isolation of all other factors is a bit of a meaningless exercise. There are other makers out there who make 3-day and 8-day movements, and Lange even made one that would run 30 or 31 days (can't recall exactly) on one wind. I also recall that the Lange was so difficult to wind they gave you a special powered tool to along with the watch so you could wind the crown.
These movement designs increase the complexity as you add in these features, and in general terms an increase in complexity typically means a decrease in reliability. They also tend to increase in size due to the additional real estate required for either one larger mainspring barrel, or two smaller barrels. Sometimes this can compromise the size of other parts in the watch, such as the balance.
One maker of 8 day watches had big troubles with overbanking when the watch was fully wound - their solution was to tell their customers to not wind the watch fully. 🤦
Unfortunately it's not so simple to say that two barrels are always better/worse than one. The devil is in the details...
Thanks Al I appreciate the information. Take Care, Charlie
I forgot to mention I heard the double barrel balances the power better and never go near a single barrel. That is what made me revisit this question I asked before.
Not sure who told you that, but I would not take any additional technical advice from them.
The 39.5mm Planet Ocean is Omega's finest hour when it comes to catering a diver for the smaller wrist. Makes me want to pull the trigger and get one for myself...
I think the 39,5 suits your wrist better...
that said, I'm on the fence for it as well but I wonder when it will be updated?
The PO was a released in 2011, then updated in 2016 so the next iteration might be announced in 2021, which is around the corner...
One has the quick set date whereas the other one has the travel time function
I'd go for the 43.5. Watches look bigger on camera wrist-shots than they do in real life.
Would definitely advise anyone to try both on. I've got a 6.2" wrist and the 39.5 fit my wrist like a glove where as the 43.5 looked cartoon-ish.
Yes, for sub 6.5 inch wrists 39.5 would be better. Also depends on wrist shape.
Flat as a pancake!
42mm previous gen is thr way to go 😀
I do like the 42mm. It has quite a sensible lug-to-lug measurement as well.
Reg the 42mm Planet Ocean - I think Fogcity Vintage has a minty unpolished one for sale. It is the Goldilock PO in my opinion.
