Omega Constellation Pie Pan
The difference is more on the dial than on the case. Here is a good looking ref. 14902.
https://shop.hodinkee.com/products/1960s-omega-constellation-reference-14902?variant=12089453445195
just for the record- this is an uncommon arrowhead dial in a dogleg case, rather than an example of what identifies a 14902.
they do pop up now and again but the dials are a left-over from the earlier lyre-shaped references.
As noted above there is very little difference (if any) between 14900/14902 and 167.005/168.005.
I think, since not being liked here that much, I second your emotion. I'm simply not good enough.
Let's take the easy way:
OMEGuy should post?
1. Yes
2. No
you possibly jump in with both feet at times
- and you may also be like a dog with a bone at times when the odds are not stacked in your favour.
however, unless you post something offensive, you have the same right as the rest of us to post your opinions (which is what a lot of members’ posts are)
- so carry on doing so.
