Omega Constellation Jumbo redial?
From a 14777 to this? Have you looked at the case?
yeah haha - personal preference came a long way and is still going
According to them:
Reference number 168.015 (34mm)
Year 1969
This is a Ref. 168.(0)015.
https://www.omegawatches.com/en-us/watch-omega-constellation-omega-st-168-0015
There should be engraving with the reference number on the back.
These watches were made in the late 1960’s. I think a 30M serial number is kind of high for this model. Be careful of a frankenwatch with this one. Also, it is not a “jumbo” Constellation.
About 35mm diameter.
gatorcpa
thanks for the input and advice!
and the "Constellation" text is correct? im so used to the "curved" n's
That constellation text is correct for early 70s and SN is 1970
Desmond’s blog has discussion and examples
thanks for your help!
i'm just used to seeing "Constellation" with curved n's
Question about bezel condition
The seller describes the watch as follows:
"The stainless steel bezel is in fine condition with only light overall wear apart from a more noticeable partial crack at around 11 o’clock."
Well, they’re basically saying there’s a partial crack on the bezel at 11..
Would you consider this a dealbreaker? Or is it just a cosmetic flaw that’s acceptable if priced right? (1400,-) Curious to hear what you all think.
Couple of things:
Curly Ns are the norm for this range of constellations but Ash does show one example of a straight N in his article.
Perhaps because it is a late version, it received a later style dial font.
A cracked bezel is an absolute deal breaker as this is a monocoque case - everything comes out through the front.
You would be unlikely to find a replacement and would probably have to have one made if it were to break.
Couple of things:
ok - very interesting! thank you!
but the partially cracked bezel is a real bummer...
guess im back on the hunt again
you're welcome.
However, I'm with @Dan S regarding the types of Constellations you're looking at.
Beauty is in the eye of the beholder and no-one can/should tell you what you like - so you have to do you (e.g. I am personally more fond of dome dials than pie-pans) but to go from a jumbo lyre lug to a stumpy-lugged bastard off-spring (can you tell I'm not keen on this case style?) is somewhat of a quantum leap.
These Constellations are also the smallest in the 60s range at 34mm and wear small because of the case configuration.
But - If this is the style that really speaks to you then hold out for the best you can find - they are not uncommon watches and as a positive, as they they aren't that popular, they should be relatively cheap too.
1400 (£$€) should buy you a mint example with box and papers.
The bezel is a deal breaker for me. It's not a part that you can plausibly replace.
The bezel crack also compromises the waterproofness. So it turns it into a ...
"It better not rain because this watch couldn't handle washing hands let alone the sea master".
I wonder though, even if this was in good shape, the private sales section here has some absolutely amazing watches for less money... Why are you not buying there?
True, but every time something good pops up here, I either miss it or don’t even know it existed (saved search would really help..)
you're welcome.
I also prefer the dome dials😀 and yeah, the lyre lugs definitely look waaay better. I guess sometimes I’m just being a bit impatient… (and thanks for pointing out that that case style wears extra small)
on the hunt again....
It sounds like you are going in the right direction
you want:
Constellation
Lyre lugs
Dome dial w dauphine hands
14393- Calendar is a nice option but there are many others- browse this thread from beginning to narrow it down, and then stick to your preference to narrow the search, and learn as much as you can about the watch you like. Patience is generally rewarded.
you want:
Constellation
Lyre lugs
Thanks a lot!
Just out of curiosity I was browsing Chrono24 and found this 18k rose gold Constellation in pretty good condition. It’s not really what I’m after, but I’m wondering why nobody seems to be going for it. I’m guessing it's the 5,440 EUR what’s keeping people from pulling the trigger? or something else?How much do rose gold Constellations usually go for? Idk rarely see them.
Indeed that's an ambitious price. You can search for comps of 18k Constellations in auction sales or forum listings. You can even look for Deluxe models. Without seeing the whole listing, we can't really do a full evaluation.
Edit: Actually, I just checked and there are plenty of comps in sold forum listings. Use the advanced search function.
The C24 watch is a 14394 (deluxe with gold dial) Constellation.
Rose gold does sell at a premium.
The watch isn’t heavily polished and is handsome but it has lost its facets on the edges of the lugs.
€5400 is a high price but gold is at an all time high at the minute.
Rear, inside case back, movt shots required for proper evaluation.
