OMEGA APOLLO SOYUZ: Happy 45th birthday
You're right. I focused on the transformation. Omega is clearly identifying these as AS commenorative. If Omega calls them AS commenorative then that's good enough for me.
Coming from the same lot as the lot that De Marchi received makes them seem to all have been likely to have been transformed by De Marchi into AS Demarchi watches. It doesn't make sense to me that only one extract says transformed by Demarchi and the other extracts would not, although I have only seen a copy of one of those besides your 468.
Here we don't agree. I am not definitively saying they are different. I am raising the question because i see differences when looking at the pictures. Of course, pictures at certain angles can make something appear to be different when there is no difference. But i see different sized continents. I was not aware that they been analyzed.
I only saw the one invoice, which is why I speculated about the low number. Are there copies of the other invoices, not including the normal speedmasters that were used to make the 46Xs?
Yes, i would not be surprised that De Marchi engraved the numbers. I would not expect Demarchi to have made the medallion with the spacecraft. It is possible, but seems more unlikely in the absence of evidence.
By parts, i don't mean a franken watch. Every watch comes from parts at the factory. I meant Omega could have taken parts from the bins and produced the 476. It's a postulate that attempts to explain the anamoly of one high numbered watch. There are a lot of postulates that are taken as established theories.
Mine are not theories. I am attempting to present a plausible alternative to test other hypothesis. There doesn't seem to be enough evidence to establish a theory. I am merely saying that given the scant evidence, this is what I as an objective reader have concluded thus far. I would expect to change my mind when more information becomes known. I certainly don't believe this is the final conclusion. Merely that at this point in time, this is what it appears to me.
The mitsukoshi was a poor example. They aren't the same but i was using it to illustrate my thoughts.
As I said, the 468 is a historically significant watch because it was transformed by a significant Italian dealer from original parts as authorized by Omega. Personally, it is not the same as the AS with the different cases. That is not the same as a mitsukoshi, for sure.
Cheers,
Dave
Thank you for the clarifications! I think we are mostly on the same page, and we both got a little lost with all the information (and the arguing of some!).
Regarding the AS 5.5 mm shipments from Bienne: I have only seen invoice 170, same as you. The others probably exist but they have not been made public. Watches have been documented from the two large shipments (200+170), not from the last two (20+10). Please don't eat me alive for this, but I have thought that the last two shipments (20+10) probably were used as spares, and maybe this is where the parts to transform the De Marchi's come from... Yes, it is pure speculation!
Watch #476 arrived in the 170 shipment. Attached is the extract, which has great detail, even the watch number, probably the result of a physical inspection.
I will try to convince the owners of #416, #461 and #469 to share their extract, if they have it.
I will send pictures of both AS's casebacks once I get #3xx.
I agree, the AS with 5.5mm pushers, the bigger case, is "pure and pristine". The AS De Marchi is "different", and with a complicated story, but still part of the family.
If De Marchi did the engraving then all 400 to 500 where somehow "finished" in Torino... I better run, I know a few that will fume if they read this, but sorry to say, it is possible.
Regards
it is clear that your spare parts today make sense as the puschers are all the same.
Pushers today are most certainly not all the same...
You are arguing points that I don’t believe you have any real understanding of...
I think you are assuming the watches were sent in order of movement. But couldn't there have been more random movement numbers in the 170 shipment?
It is certainly a plausible conclusion to believe there are 400 watches based on the movement. I am not as certain yet. Of course, it's surprising any invoices still remain so in the absence of invoices we need to make some conclusions, i get that. I am not trying to be argumentative, although I am arguing the point, which is to present a plausible alternative.
Thanks for clarifying.
This is what has been published... The AS 5.5mm Bienne watches, the pure and correct, have movements in this range: 39.180.860 to 39.181.389 (529 movements). And shipments happened in a short time, four months (april-july 1976), so most likely they were all mixed. and then #LE numbers assigned who knows how considering they were most likely engraved in De Marchi Torino.
Regards
it is clear that your spare parts today make sense as the puschers of the X 2020 model are all the same (they have the same size!), instead this AS, even if produced in the same year as the traditional Speedmaster had different puschers.
the problem is another; if these 5.5 puchers were produced for the APOLLO SOYUZ why were they not fitted to all Apollo Soyuz?
here the record starts again ...
because De Marchi has transformed the Speedmasters with what he had at home ..
right?
is this your thought?
I understand, but why does OMEGA send 100 bracelets to De Marchi and not 200 puschers?
but then, why assemble them in a bad way, as the idea of the Apollo-Soyuz limited production was proposed by De Marchi!
it seems to me that puschers are easier to make than a bracelet and also cheaper.
I guess you don't have the answer, do you?
if it makes you happy, neither do I.
I'm just thinking about what could have happened in OMEGA or De Marchi and I can confirm that your doubts are as good as mine. If Omega is not able to know if a shipment of accessories has been made to De Marchi, it does not mean that I am right and you are wrong; the invoice may have been lost .. simple and the case is closed. I say that even this hypothesis seems a bit strange to me because ... the Omega Museum has found all the documents of all the shipments and only this is missing ... this makes me doubt ...
just for you confusion ... why have all the Rhodesian Airforce speedy also the 5.5 punchers ?
I guess because Omega used the same case that they used for the AS 5.5mm shipped from Bienne?
if I'm not mistaken, only the 1976 AF2 with 39.180.xxx movement had the same case and pushers as the Apollo Soyuz. unfortunately I don't know the exact number of watches reserved for this military body. I add that I cannot explain if there is a relationship between the AS and these military Speedmasters.
I don't know if others have reliable information on this model.
You base a lot of your theories on certain assumptions that "make sense" to you. You questioned why anyone would have 200 pushers, because no one really changes them. I told you I stock 30 of one type any any given time (I also stock several types), so 200 for a large shop is not out of the question. You countered with nonsense about modern pushers being all the same, so it's not apples to apples from then to now.
What I'm trying to explain to you is that these assumptions are not always accurate. I've already told you that all currently used pushers are not the same, yet you keep telling me they are:
So I took 5 minutes to look up some models and what pushers they use:
Speedy Tuesday 1 - 086STZ006871
Speedy Tuesday 2 Ultraman - 086ST0059
Current 3861 Speedmasters - 086STZ013181 (also for silver snoopy)
Cal. 321 Speedmaster - 086STZ011936
First Omega in Space - 086ST0194
1957 Trilogy - 086STZ006949
So as you can plainly see, contrary to what you keep telling me, modern pushers are not all the same. How this impacts the bigger picture I'll let others decide, but you should be aware that some of the assumptions you are making here are not at all what you believe they are.
The 5.5 pushers required a modification of the case, right? So I would scrutinize the case instead of the pushers. Those could have been replaced by standard ones during a service.
I also read some arguments in favor of AS De Marchi because of how they could have got the bracelets (on top of the rest, but let's focus on the bracelet to get this part out of the discussion...)
1168 was sold for several models: 135.041, 135.042, 135.070, 136.041, 136.070, 165.041, 165.070, 166.041, 166.054 and 166.070. The date no/date are sharing the same case, on the contrary of automatic/non-automatic. So the bracelet was made initially for those 3 models / 6 cases. It was before the Apollo-Soyuz mission was even discussed between USA and Russia. I am not even sure man walked on the moon before this bracelet exists...
And while it may be not the most common bracelet, it is not rare either. Right now I can find more than 10 of them available for sale thanks to a 2min search. The price range is quite large...
Now, how could De Marchi have added the numbers on the caseback without overlap? Simple: the AS was exclusive to them. At the very least they knew all the numbers that were allocated. Most likely, they were the ones engraving all the LE #. That would also explain why Omega cannot relate the LE# to the serial, the archives not listing the De Marchi "modified" ones, and the gaps (095 is doubtful, though...)
You have to remember the AS was commissioned by De Marchi for the Italian market. It was not initiated by Omega.
Bienne could have validated the design and let De Marchi order watches (as well as spare parts) as much as the Italian company felt. After all, it looked nice and De Marchi was paying. No risk for Omega. They might have no idea about how limited it will be. In the end, the only thing they got was 3 (4?) orders of complete watches for a total of 400 of them. The rest, only De Marchi can tell... What we know is they were entitled by Omega to modify watches, and it was common for them to assemble watches from parts.
And I doubt Omega keeps track of spare part orders from 50 years ago. After 10 years those are not useful anymore from a legal point of view. They are not useful either to authenticate a part as there is no serial on it... And, it takes space to store. Better to just get rid of the paperwork as soon as the legal duration comes to its end.
Let me elaborate further, and let's assume for a second that Fratelli Di Marchi controlled the numbering and did the engraving, which makes sense because numbers do not repeat, and engraving was done manually, using a pantograph, and the font is the same on all known watches (from #6 to #476).
Lets combine this with the facts I have documented during the week, which are:
a) Omega shipped 158 standard Speedmasters to De Marchi in june of 1975 (I published the invoice in a previous post)
b) Omega made four shipments of AS 5.5mm Speedmasters from april 1976 to july 1976 (200+170+20+10). This means that a large number of AS casebacks was not available in Fratelli De Marchi until april 1976. There is not known AS 5.5mm watch coming from the shipments of 20 and 10 watches.
c) There is no evidence that a large number of parts was shipped from Omega to De Marchi (bracelets, dials and casebacks). It is very likely that small number of parts were shipped for service purposes, but not in the hundreds.
d) There is no evidence when the "transformation" of standard Speedmasters to AS De Marchi's occurred, but it happened at De Marchi because AS De Marchi watches #416, #461, #468 and #469 come from the batch of 158 standard Speedmasters indicated in a)
e) The existence of AS 5.5mm #476 is well documented, the watch arrived in may, 1976
f) AS watches were sold from 1976 until the early 80's (though there is hearsay that some were on display in late 1975).
g) AS De Marchi #461 was sold to the first owner in May 8, 1981 (information was made public years ago, and the papers were published).
h) It is also documented that Fratelli De Marchi was behind the idea of doing the Apollo Soyuz commemorative LE Speedmaster, they were the exclusive distributor, and they were authorized to transformed watches (as documented in their contract, which was made public, and accepted by Omega in the extract of AS De Marchi 5mm watch #468)
So... a large number of AS casebacks was available for engraving in april of 1976... then more in may, and july, for a total of 400 casebacks (that came together with equal number of fully assembled AS watches, with dials, bracelets, modified cases, and larger 5.5mm pushers). The lowest number known is #006 and the highest is #476, which is a total of 470 known numbers assigned and used. This is what sustains the theory of the probable existence of 70 AS De Marchi 5mm, but only a few have been identified.
We don't know if Fratelli De Marchi engraved all the casebacks in the first semester of 1976, or if they did it throughout the period that they were selling the AS watch, but must likely they engraved at least a good portion of the 370 in 1976 and more later, probably until the early 80's. Most of the watches sold were AS 5.5mm (that have the modified case). Why did De Marchi decided to transform some standard Speedmasters to AS? We don't know. When? We don't know, but the standard Speedmaster watches they used were available at their facility since june 1975.
So again, for me an AS De Marchi 5mm must comply with the following:
a) Originate from a standard Speedmaster shipped from Omega to Fratelli De Marchi Torino, since the AS project was exclusive to them.
b) Must have the correct dial, bracelet and caseback
c) Must have a number assigned that doesn't repeat (same font, etc)
Anything different, in my opinion, is questionable.
This is (exactly) what I have been explaining through the week, which is basically when I started posting in Omega Forums.
I am sure that some of you will respond with opinions, or theories, but the facts are there to establish a clear boundary that: a) the AS De Marchi 5mm exists, b) it legit, and, c) the transformation (of up to around 70 watches, probably less) occurred must likely from 1976 until the 80's. Unless someone can provide additional evidence, these are the facts, regardless of what you think, or are inclined to believe or your opinion.
As a collector I wanted to have both watches, an AS De Marchi 5mm and a AS 5.5mm...
The AS De Marchi 5mm is valuable for historical reasons.
The (monetary) price is a different story, the AS De Marchi is valued at around 50-70% of the AS 5.5mm, but I am confident that at one point the AS De Marchi 5mm will not be that far from the AS 5.5mm or why not, could do even do better because there are far less, and/or if someone is able to demonstrate that they were sold in late 1975 (there is no hard evidence of this, only hearsay).
Here is a picture of Carlo de Marchi. I wish he was alive to explain all this! Or at least have access to all those files behind his desk...
Regards
Based on the look on his face, Signore Carlo purposely created some mystery.
Please re-read my first thread and all others related to Apollo Soyuz as well. You will not find any notes referring to modern pusher mounted on modern watches.
Mine was a simple reflection made with you and if you tell me that 200 puscher spare parts are not impossible, I believe you.
anyway I'm sorry for you, surely this comparison of ours or my statement about modern puchers will not "affect the bigger picture", trust me!
At this point your considerations on puschers are very clear, what is not clear to anyone is your position regarding the birth of the Apollo Soyuz OUT of Batch.
Based on the few concrete evidence at our disposal; we know that many of the Apollo-Soyuz OUT OF BATCH watches were contained in the shipment of the 158 watches that arrived at the Italian distributor.
That said, are you among those people who think that De Marchi, after receiving these 158 Speedmasters, turned these watches into AS out of batch?
On June 12, 1975 Omega invoiced and shipped 158 Speedmaster Professional watches to De Marchi Italy with invoice 061258 and were received in Turin on June 23, 1975. A subset of these are the Omega Speedmaster Apollo Soyuz ‘De Marchi’ watches. The movements series do match.
There is evidence that AS De Marchi #416, #461, #468 and #469 come from this shipment, and the transformation only included the dial, bracelet and caseback with a unique LE number. They don't have the modified case and larger pushers (5.5mm), or different pushers than the ones coming from a standard Speedmaster.
"Many", at this point is limited to a small number of watches...
I am not talking here watches that: only have the correct dial, or a faded caseback, or that come from Speedmasters shipped other than to Fratelli De Marchi, in the period 1975-1983, like some being sold on e-Bay which have an unknown origin.
There are many opinions, and there are facts.
Progress has been made after doing a better interpretation of the available data, but no additional evidence has been produced in the last six months that is relevant. I'll like to know where the AS "out of batch" in the 200's come from, and a few others. More collaboration is needed from the owners of these watches, to have a better understanding.
Something interesting to me is that, based on what I have seen, the highest known number in the 300's is #355, I don't think any AS 5.5mm Bienne watch has been identified above #355 and in the 300's range.... Extracts of the watches that have been made public all come from the shipments of 200 and 170 AS 5.5mm Bienne watches, nothing from the shipment of 20 and 10.
Thank you
Well, you were the one that brought this up in this thread, not me or anyone else. You initially implied that no one really changes pushers, yet they are replaced at every service, so again there are assumptions you are making that are just off on what really happens in watch servicing, which is my area of expertise.
So you are suddenly fine with something you argued against, but now consider it irrelevant. Is that right?
As you say, there are a lot of unknowns. Personally I'm fine with accepting the mysteries surrounding this as I am not invested in any manner in the outcome. If I see misleading or ill informed conclusions, I'll do my best to add clarity to the discussion where I can.
The following could explain some watches with serial numbers that are not in the correct range. The entire movement could have been replaced. According to this post, Omega had a policy in the 70's to replace entire movements. So finding a few watches with odd serial numbers could simply mean that the movement was replaced.
This isn't a statement about what took place with any AS model. It simply illustrates the wide range of possibilities. It reinforces for me that it is interesting to conjecture about possible scenarios, but absent facts, they are simply conjecture.
_____________
I can't believe that after all these clarifications of yours, you end up not telling us your personal thoughts on this story!
everyone said their idea / hypothesis
not sharing your hypothesis (even if it is as wrong as mine ... as others say ...) allows us to reason all together.
forums were born for this!
if in the most important moment of the speech you make a silent scene ... forgive me but ... even the rest you have said so far is worth nothing to me!
after all .... useless discussion with no prove of anything and the only outcome is potential buyers are so uncertain about right and wrong and nonsense so they will go and buy something different. bummm price drop..... well done OF
luckily i don't have to care as i am not in the AS game
Interesting view. But it would be unfortunate if it was the prevailing view here. There have been a lot of threads here where knowledge has been gained by efforts of many, where things that were once in question are now much more clear. While this thread suffers from a lack of facts and an excess of theories due to the nature of the reference, if we are now suggesting that discussions should be stifled to protect value of specific references, that would be very unfortunate.
As Mick once said, you can't always get what you want. You are forgiven.
