OMEGA APOLLO SOYUZ: Happy 45th birthday
One aspect that could help clarify the discussion (at least for me) is the number of watches being discussed. It's seems there are only a few, perhaps as few as 7. I have read conclusions stating as many as 70 to 100 or other statements that seem to indicate there are many watches. But we keep coming back to one, two, or as many as seven.
From our discussion here, I think we have agreed that any watch with only a dial is illegitimate, so my assumption is that we would only raise evidence from a watch that has all elements except the case and 5.5mm pushers. Again, those are very few. There may be many watches with only the AS dial but if we agreed that they are not legitimate then we can ignore those, correct? (I am assuming the 286, 288, 416, 461 and 468 all have every element except the 5.5mm pushers, which we are referring to as the AS Demarchi group.)
The reason I bring this up is frankly, it is problematic to me to draw conclusions about an entire production based on an oddball watch or two. I now understand why people approach this with scepticism.
Also, did you have a follow up discussion with Omega regarding the other elements besides the serial number? I myself would not be able to draw a conclusion about whether a watch is authentic based on this one discussion with Omega. Omega simply did what everyone does when evaluating a watch, they went to the most obvious data point, which was the serial number. No sense looking further if the first data is incorrect. So once you determined the 416 was a normal speedmaster shipped to De Marchi, what did they say next? (I apologize if this was already discussed.)
From what I have read thus far, the 416 does not have an extract from Omega stating it was transformed but the 468 does have an extract saying it was transformed. Is this an accurate statement?
I am not sure about 286 and 288... I don't know the movement numbers.
Attached is the invoice where 416, 461, 468 and 469 come from.
Dials and bracelets are correct. The other important element is the number of the watch itself.
I am not aware of many AS with 5.5mm that have numbers above 400 (like #476, delivered in Torino in May 1976). The pieces identified as "De Marchi's" all have high numbers, no repeated numbers have been found, so there are around 70 watches that could be AS 5.5mm or AS 5mm. Actually to my knowledge there are more AS De Marchi's 5mm identified above the 400 number, than AS Bienne 5.5mm... This last statement justifies the relevance of the AS De Marchi watch.
In my opinion there is enough supporting data, and well defined boundaries.
Yes, there is room to be "skeptical", and we all have an individual "threshold".
The "skeptical" view can be applied to many other vintage Speedmasters (60's/70's racing dials variations grey/black, Ultraman, straight writing/racing dial for Japan, grey/blue dials, Meister, moonphase dial variations, etc, etc...). For many of these watches you only need to replace a dial, or a caseback (not even both components), with no worries about a limited edition number, in some cases not even worry where the watch was originally shipped too, and do so on a Speedmaster from the same era, to create "something".
The AS De Marchi watch, for some reason, has been scrutinized far more than others, which is ok, so, as a consequence, more work has been done to sustain where we are on the AS De Marchi... Far more research as compared to many Ultraman or Racing dials watches that have been sold in recent years.
I am only sharing my thoughts, not trying to convince anyone.
Take care
Replacement dials are available from Omega if you need one - part number is 064QMZ010527. 馃槈
Good to know. Probably also the case back is available...
I got my watch from the Omega boutique.
I am not aware of many AS with 5.5mm that have numbers above 400 (like #476, delivered in Torino in May 1976). The pieces identified as "De Marchi's" all have high numbers, no repeated numbers have been found, so there are around 70 watches that could be AS 5.5mm or AS 5mm. You have to add to the equation that there is no precise timing of when the transformation occurred.
Okay, so not many watches, just 4 with 5mm pushers, 2 with unusual serial numbers, and one with correct pushers and above 400 (i.e. 476).
To me, the invoice simple shows that the 4 watches came from watches sold to De Marchi. It doesn't mean that De Marchi converted or even intended to convert all of those watches. It just means they ordered normal speedmasters to sell.
The compelling evidence is your extract from Omega for 468. But even that simply establishes that De Marchi transformed watches with original parts. It does not establish that Omega considered them part of the AS LE.
The extracts are key. If the other 3 watches do not have an extract that says they were transformed or identifies them as having AS dials at least, then for me, i would place a higher probability on them being illegitimate, even though they came from De Marchi.
One additional area I haven't read discussed is the caseback. The engraving of the medallion space crafts looks different on those casebacks. The size of the continents and rocket look different to me. Has anyone else noticed this?
It seems strange to me that there were supposed to be be 400 or 500 of these but there is one known invoice of 170 AS watches sent to De Marchi (the one's with 5.5mm pushers converted by Omega but sold by De Marchi.) Given that these were not hot items and were slow sellers, it seems reasonable to think that's all that were ever available, only 170. And of those, it seems reasonable to think many did not sell, which is consistent with only about 40 known watches. Regarding number 476, it seems possible to me that there was a random one-off order later for a watch and Omega grabbed one or put one together from random parts, which became 476. I don't think that because this watch is numbered 476 that it proves there were 475 watches before it.
The mystery for me is where are the rest of the AS watches from the original invoice of 170.
EDIT: one more thing about the original 170 AS sent to De Marchi, we should not assume they were numbered in order. They very well could have been randomn numbered casebacks that were grabbed by Omega and mailed out to make up the 170 ordered. #476 could also have been in here.
I am leaning towards discounting any watch that does not have 5.5mm pushers as being an AS watch. I would love to own a De Marchi transformed watch myself and think it has a historical significance, but personally I would not place it in the same value as an AS with 5.5mm pushers. To me, it's more like a watch with a Mitsukoshi dial added. Still a speedmaster, still an original dial, still a cool watch, but not part of the original edition.
This is an interesting discussion. Thanks for everyone sharing the fruits of your hard work and research.
Last thing, yes, there is a lot of discussion about this but I don't think it is the most discussed speedmaster watch. There is a lot of discussion about that ultraman chronograph hand for example. A lot. This seems pretty normal for a special watch.
Cheers,
Dave
I've changed lots. Although I don't keep 200 in stock, I probably have 30 in stock at any given time, and I'm a one man shop.
... what comparison do you make?
Omega production in 1975 was quite limited. it seems to me that in 2010 Omega produced 10 million watches and consequently the number of spare parts is proportional to the number of watches produced. I don't think that if the production of the AS was set for 500 watches, Omega did not produce 200 more dials. in any case, I really like this reflection of yours and I would like to submit it to the former De Marchi employee.
thank you
thank you
Wait you think 10,000,000 watches where made by omega in 1975?
why? I think I know your answer and it contradicts your theory on everything.
I absolutely did not write that in 1975 (in 1975) Omega had sold 10 million watches I wrote that the number of spare parts is proportional to the number of watches produced and that the watches sold in 1975 are not comparable to those of 2010. I don't think that if the production of the AS were set at 500 watches, Omega would not have produced another 200 dials.
thank you
200 dials? I answered a question you asked about pushers. This thread gets so confusing (wondering if intentionally sometimes) because people don't take the time to explain what they are saying. They assume everyone is on the same page but often that is not the case.
I simply answered your question, asking who here has ever changed a pusher - I change them all the time mate. I keep plenty in stock, and I would expect any shop that sells and services watches to do the same.
Your the one presenting things as facts when they are not. You constantly make 2 logical errors on n your deductions.
the first is basically this. Prove unicorns do not exist. You prove it by saying it be not seen one nor has anyone I know. The problem is that is not proof.
2nd logically in the mid to late 70鈥檚 the things that everyone has have postulated make way more sense then your explanation.
so funny!
I don't believe in unicorns because I've never seen one ... instead you believe in unicorns, fairies and even Santa Claus.
you're too strong ...
I have already told you a thousand times that I have lost faith in Omega. Many of Omega's claims were quickly disproved while others took years. I'm just saying that after so many bad experiences, now I only believe it if I see it.
this is my problem.
but as always, your comparisons never hit the spot. here we are not talking about unicorns, we are talking about someone who has assembled watches with spare parts never received and perhaps never produced. I truly believe that I will continue to make the usual mistake, you're right; I will continue to ask Omega why he has been hiding the truth for years and what overwhelming evidence prompted Omega, only now, to include this new "note" in the Abstract Archive.
what is the decisive proof?
perhaps a more detailed and more careful research?
because today everything is clear and years ago it was all a hoax?
For OMEGA Was it enough to ask Mr Haterama?
until that moment the dialogue between you and me (and I apologize to those who are reading) will continue to be a broken record ...
so funny!
this is my problem.
No, I do not believe they exist, but the reasoning you are using to prove they do not exist is saying it must not exist as you have not seen one. I cannot prove you are a not a 3 foot tall green man that lives under a bridge, but since I have not seen proof otherwise am I to assume you are? That is your logic. In cases like this which you try to disprove a negative, all you can say is the preponderance of all evidence seems to state they do not exist. You pick and choose and even contradict yourself in your "proof"
That is a logical fallacy. You keep saying they never sent dials to De Marchi as you have not seen an invoice for them. YOU CANNOT MAKE THAT LOGICAL LEAP. You simply cannot disprove a negative its impossible. Yet you are using that to claim they never sent dials to DeMarchiu, while you admit they sent dials to demarchi for them to assemble the watches. You constantly contradict yourself, or use flawed logic to prove a point.
You also admit the extract process has issues and can be inconsistent esp in the notes section, but refuse to think that might be the case when you have 1 or 2 extracts that says what you want it to say, and there are way more which dispute what you claim as fact. Why do you only accept data that agrees with your stance? That is called confirmation bias. You admit that De Marchi made watches from kits, but the watchmaker claims they never did. So which is it?
All I am saying is stop claiming these are facts that you have not proven until you can actually prove it. You have a theory, and most people think that your theory makes no sense in how things are actually done and the time period, people spot the multiple problems with your theory that you fail to resolve. You do not appear to even be able to see the basic contradictions in your thinking.
you are right, I apologize if I wrote dials instead of buttons.
together we reflected on the number of spare parts that should have arrived at De Marchi at a time when, most likely, there was no need to keep mountains of spare parts as the watch in question had only been produced in 500 copies.
consequently it is not clear what is the reason for producing and maintaining an important number of buttons, dials, bracelets, etc ...
it is clear that your spare parts today make sense as the puschers are all the same.
Greetings Good People,
I love this thread - such is the passion of watch collecting!! I've just ordered an extract for mine (233) so as help fill in one more gap in your table. I also have wasted too many hours of my life researching this reference, only due to my personal history relating to this watch when I lived in Russia.
I can contribute a little more to fill in some data points - alas nothing more on the story of the source of the semi-official Apollo-franken-Soyuzs 馃槻馃槑.
So, facts only here, no speculation...
No.006 movement number is 39,180,905 and its Extract production date is 12th April 1976 (not 3 May).
https://www.fratellowatches.com/
No.092 on the list is actually No.097. I've never seen evidence of No.092, but No.097 is definitely 39,180,966.
https://catalog.antiquorum.swiss/en/lots/omega-ref-145-022-speedmaster-soyuz-lot-324-603
https://issuu.com/antiquorumgenevesa/docs/flipflop (Page 330)
No.202 has movement 39,181,xxx and an extract showing production date of 12th April 1976.
https://www.lieblingskapital.de/products/omega-speedmaster-1
39,181,362 was indeed sold at Christie's and their lot info states that the extract has a production date of 3rd May 1976. I don't know what the caseback ref no is.
https://www.christies.com/lot/lot-omega-an-extremely-rare-and-fine-stainless-5993023
39,927,934, the watch sold in Omegamania was originally sold on January 31, 1978 according to the auction info. https://catalog.antiquorum.swiss/en/lots/omega-lot-158-19
now there are two hypotheses:
- read one thing but understand another
- I'm dreaming
please search and find me in all my posts where i mentioned the word OMEGA KIT
do it now!
what the hell are you saying!
I have been saying for 13 years that the watches come from Omega and now you tell me I am saying otherwise?
The former De Marchi employee confirmed that there was no transformation and you tell me that you understood the opposite?
Mr. HATERAMA strikes again ...
the only illogical and useless here is you!!!
I have received hundreds of compliments for my research and certainly Mr. Hater will not persuade me to let it go.
take it easy
The 5.5 pushers required a modification of the case, right? So I would scrutinize the case instead of the pushers. Those could have been replaced by standard ones during a service.
I also read some arguments in favor of AS De Marchi because of how they could have got the bracelets (on top of the rest, but let's focus on the bracelet to get this part out of the discussion...)
1168 was sold for several models: 135.041, 135.042, 135.070, 136.041, 136.070, 165.041, 165.070, 166.041, 166.054 and 166.070. The date no/date are sharing the same case, on the contrary of automatic/non-automatic. So the bracelet was made initially for those 3 models / 6 cases. It was before the Apollo-Soyuz mission was even discussed between USA and Russia. I am not even sure man walked on the moon before this bracelet exists...
And while it may be not the most common bracelet, it is not rare either. Right now I can find more than 10 of them available for sale thanks to a 2min search. The price range is quite large...
Now, how could De Marchi have added the numbers on the caseback without overlap? Simple: the AS was exclusive to them. At the very least they knew all the numbers that were allocated. Most likely, they were the ones engraving all the LE #. That would also explain why Omega cannot relate the LE# to the serial, the archives not listing the De Marchi "modified" ones, and the gaps (095 is doubtful, though...)
You have to remember the AS was commissioned by De Marchi for the Italian market. It was not initiated by Omega.
Bienne could have validated the design and let De Marchi order watches (as well as spare parts) as much as the Italian company felt. After all, it looked nice and De Marchi was paying. No risk for Omega. They might have no idea about how limited it will be. In the end, the only thing they got was 3 (4?) orders of complete watches for a total of 400 of them. The rest, only De Marchi can tell... What we know is they were entitled by Omega to modify watches, and it was common for them to assemble watches from parts.
And I doubt Omega keeps track of spare part orders from 50 years ago. After 10 years those are not useful anymore from a legal point of view. They are not useful either to authenticate a part as there is no serial on it... And, it takes space to store. Better to just get rid of the paperwork as soon as the legal duration comes to its end.
OK.
Cheers,
Dave
What an interesting response...
I will try to focus on what you are questioning, and not address your theories (with no evidence).
1) The two watches in the 200 range presented as AS De Marchi are not "unusual". I only said I don't have the information to make an opinion, so why label them?
2) The extract for watch #468 clearly says it is a "AS commemorative edition", and there was only one AS commemorative edition in the mid 70s, so, I don't get it. You can find my extract in a previous post.
3) Watches #416, #461 and #468 are confirmed to come from the same June 1975 invoice, and they have LE unique numbers. #469 most likely too. For #461 there are even the papers. Maybe the owners want to share their extracts. I know two of them. I will ask.
4) I don't agree with your caseback statement, they are the same. The casebacks have been compared, even the engraved numbering was compared, which was done using a pantograph.
5) There were at least four shipments of AS 5.5mm watches, and many of the known AS 5.5mm have been identified from the shipment of 170 watches and the shipment of 200 watches. It will also be interesting to know where are the 1,014 LE moon landing watches, I think that if you spend a year searching you will not find more than 100-150. Same case here.
6) There is no conclusive information about who did the engraving for all the watches. It is possible that De Marchi controlled the numbering and did the engraving.
7) I also know the owner of watch #476. He has his extract. It was not made of "parts" as you are suggesting.
I don't agree with your overall conclusion, because it is not objective. You are assuming that your theories are right, discounting the facts.
You are only using "the dial" as the evidence, but not only a dial was added... Also the bracelet, the correct caseback, a unique LE number that doesn't repeat, and it is documented that the Speedmaster was shipped to De Marchi, and it was transformed at some point, which lead Omega to issue the extract.
Finally, an AS De Marchi is NOT only an Speedmaster with a Apollo Soyuz dial (like your Mitsukoshi example)... If that is what you want to read from all the information I have provided, yes, I am with you, it can be discounted.
Done here. I will go and check on the Ultraman.
Thank you
Thanks, more to think about.
Yes, we should actually focus on the case. It has a deeper facet and can be distinguished from the non-5.5 mm case. People use 5.5 pushers as short hand but I agree that the case is more significant than just the 5.5mm pushers.
I am not entirely clear on your thoughts. I don't disagree with your points. Did i give the impression that I don't think De Marchi transformed watches? I did not mean to say that. I trust that he did. I think you were making the point that De Marchi had access to the bracelets so could have used those in the transformation, which makes sense.
I missed the pqrt that demonstrated De Marchi received 3 shipments of AS watches from Omega. That would explain where the 400 number is from. I have only seen the one invoice of the 170 watches. Are there copies of the other invoices? Not disputing you, just would like to see them.
Thanks,
Dave
I agree that there is no evidence that the 400 (200+170+20+10) AS 5.5mm pusher watches left Bienne with the LE engraved. Most likely De Marchi controlled the numbering and the engraving, absolutely agree, this is why numbers don't overlap. De Marchi transformed some Speedmasters to AS De Marchi using their inventory of standard Speedmasters. They received a large order, 158 pieces, in june of 1975, and this is where the De Marchi's I know come from.
These were the Omega shipments of the AS 5.5mm pusher watches:
200 watches - April 12, 1976 - confirmed with documented watches either sold privately or in auctions, such as the extract of archives from watches #006 and #100 (recently sold).
170 watches - May 3, 1976 - confirmed with Omega invoice, and extract of archives of watch #476.
20 watches - May 11, 1976 - I have not been able to document any watch from this shipment.
10 watches - July 5, 1976 - I have not been able to document any watch from this shipment.
Regards
You're right. I focused on the transformation. Omega is clearly identifying these as AS commenorative. If Omega calls them AS commenorative then that's good enough for me.
Coming from the same lot as the lot that De Marchi received makes them seem to all have been likely to have been transformed by De Marchi into AS Demarchi watches. It doesn't make sense to me that only one extract says transformed by Demarchi and the other extracts would not, although I have only seen a copy of one of those besides your 468.
Here we don't agree. I am not definitively saying they are different. I am raising the question because i see differences when looking at the pictures. Of course, pictures at certain angles can make something appear to be different when there is no difference. But i see different sized continents. I was not aware that they been analyzed.
I only saw the one invoice, which is why I speculated about the low number. Are there copies of the other invoices, not including the normal speedmasters that were used to make the 46Xs?
Yes, i would not be surprised that De Marchi engraved the numbers. I would not expect Demarchi to have made the medallion with the spacecraft. It is possible, but seems more unlikely in the absence of evidence.
By parts, i don't mean a franken watch. Every watch comes from parts at the factory. I meant Omega could have taken parts from the bins and produced the 476. It's a postulate that attempts to explain the anamoly of one high numbered watch. There are a lot of postulates that are taken as established theories.
Thank you
Mine are not theories. I am attempting to present a plausible alternative to test other hypothesis. There doesn't seem to be enough evidence to establish a theory. I am merely saying that given the scant evidence, this is what I as an objective reader have concluded thus far. I would expect to change my mind when more information becomes known. I certainly don't believe this is the final conclusion. Merely that at this point in time, this is what it appears to me.
The mitsukoshi was a poor example. They aren't the same but i was using it to illustrate my thoughts.
As I said, the 468 is a historically significant watch because it was transformed by a significant Italian dealer from original parts as authorized by Omega. Personally, it is not the same as the AS with the different cases. That is not the same as a mitsukoshi, for sure.
Cheers,
Dave
Thanks,
Dave
I have only seen the invoice for 170. To my knowledge the invoices for the other shipments have not been made public, or maybe don't exist. The first shipment was 200, then 170, then 20 and 10 = 400. The movement number is what matters.
I think you are assuming the watches were sent in order of movement. But couldn't there have been more random movement numbers in the 170 shipment?
It is certainly a plausible conclusion to believe there are 400 watches based on the movement. I am not as certain yet. Of course, it's surprising any invoices still remain so in the absence of invoices we need to make some conclusions, i get that. I am not trying to be argumentative, although I am arguing the point, which is to present a plausible alternative.
Thanks for clarifying.
I don鈥檛 know enough about the history of extracts to speak with confidence, so genuinely asking: is it possible this extract was written during a time when the purchaser of the extract had (could have) influence over what was written? Leading to differing extracts(?)
