DIV
·Thanks Al....you are always so helpful!
I received it! Beautiful. It was only very slightly polished and works like a charm. The spots on the dial that were visible on the first photos are hardly noticeable under normal light condition. It indeed has the quick date feature. Only the crystal is not an Omega signed one, but I have a mint spare crystal from Omega (with lens, which I personally prefer).
Thank you all for your comments. Next may be a chronometer version 168.024.
....looking at the 166.010 and the 168.024, they are VERY similar. In fact, are they not identical? What's the difference? Is the 168 the later replacement of the 166?
Looks like they share the same caseback...
The 024 powered by a chronometer 564.
The 010 powered by a non chronometer 562 or 565.
Yes, the double ref. caseback is confusing, but if you know what the numbers represent, you know witch reference is the correct one for different watches. The 8 in 168 is for chronometer, making cal.564 watches 168.024's and cal.562/565's 166.010.
See http://www.old-omegas.com/omrefcod.html
Same case, yes.
Hello,
I have just bought this Omega Seamaster 166.010. It is in reasonable condition. The dial shows some spots, but nothing serious (can this be restored by a professional watchmaker?). The case doesn't seem to be polished too much. The 'S' in Seamaster is already the later style with more rounded curves, but the crown is still the ealier one.
I haven't received the watch yet and the pictures came from the seller. I don't have a photo of the movement, but the watch was serviced in 2015 and apparently runs accurately. The description mentioned a quick date set feature, so I assume it is a Cal. 565 (or 563?).
Roger
From what can see 166.010 / 168.024 cases top lugs and bezel are supposed to be polished from factory while the day date sibling (166.032 / 168.023) are brushed?
