My 2021 3861 Speedy Hesalite - Photo Heavy
Are those both the 3861 bracelets? I understand the difference but they really look different and even different widths?
They are the same except for the differences in finishing.
Does anyone knows where does the small thickness difference between the hesalite and the sapphire version resides? The sapphire is 0.4 mm thinner (13.18 mm vs 13.58 mm) according to the specs have seen; wonder if it’s thinner because the front sapphire crystal is less tall than the hesalite or if it’s beacuse of a thinner caseback.
Does anyone knows where does the small thickness difference between the hesalite and the sapphire version resides? The sapphire is thinner according to the specs have seen; wonder if it’s thinner because the front sapphire crystal is less tall than the hesalite or if it’s beacuse of a thinner caseback.
I think the only difference is the crystal. The case should be identical. I'm guessing without really knowing.
Yeah the hesalite dome is higher, giving away to a thicker dimension. Though because of sapphire weight, the sapphire option is actually heavier and actually not as balanced with the weight as the hesalite option. Maybe not the biggest differences but enough to make one decide one may be more preferable, depending on ones preferences
Thanks. Does anyone knows if the movement decoration is different between both versions? Aftermarket sapphires are already available so would be easy to put one on the hesalite version to expose it just as on the sapphire sandwich
Same movement between hesalite and sapphire sandwich. No difference between decoration.
