Longines 30CH Reference 5967
Yes, it is exact that dial, minute and hour hand are different and serial number is 8815358. As you notice, it is remarkable that Longines still used that dial layout a decade later.
Thank you for the information!
To make things even more interesting, below is a 13ZN with a visually identical dial to the 30CH above
I will amend my, "visually identical," statement and say typographically similar. I will also add that, of course, 30CH and 13ZN dials differ in the location of their feet. Furthermore, the 13ZN dial may be flat whereas the 30CH dial may be convex.
Very interesting to have part in your detailed knowledge, thanks for sharing it and I learn much 馃憤
A recent discussion has prompted me to provide a brief overview of the Longines reference 5967. This is one of the most prevalent 30CH references. Based on examples that I have seen, production spanned almost the entire late-1940's to late-1960's run of the 30CH.
I will start with an image from a 1957 Italian catalog (source: https://www.vintagelongines.com/#history). As you can see, the diameter is around 38 mm and the case is 18K gold. I have seen both yellow and rose gold. All cases that I have seen have hammerhead 170 (more information here: https://www.vintagewatchstraps.com/swisspdm.php#pdm1).
Next is an image of the price from the same, 1957 catalog.
Here is an example of an early 5967 (source: https://mimandcroket.com/project/longines-30-ch-chrono-rose-gold-two-tone-dial/). You can see the distinctive, faceted lugs that are characteristic of this reference. The dial has applied markers and an applied emblem. Also, note the red cap jewel on the balance cock. This is indicative of an early 30CH. Crown is correct and unsigned.
Now, a slightly later 5967 (source: https://www.sothebys.com/en/buy/auc...8/longines-reference-5967-yellow-gold-flyback). The dial has been crudely refinished. It is tough to tell, but the markers and emblem are not applied but embossed. Also, note the clear cap jewel on the balance cock. Crown is correct and unsigned.
Here is an example with an original dial to demonstrate the embossed markings and emblem (source: https://www.gros-delettrez.com/lot/91910/8847197). Note that some 30CH dials have embossed markers and an applied emblem.
Next is a later 5967 (source: https://mentawatches.com/product/longines-30ch-chronograph-6/). Again, the dial has applied markers and emblem. Note that the movement has lost its Geneva stripes. Crown is correct and signed.
Finally, a very late 5967 (source: https://omegaforums.net/threads/longines-30ch-530-numbering.93404/). Again, applied details on the dial. Movement is now marked 530. Crown is signed.
Hopefully, that was of some interest. I chose not to discuss the hands as my focus was more on the case and movement. If you have any questions, or a 5967, please feel free to ask and/or share.
Just starting to get into Longines 30CH and found this post very educational. Thank you for all the information and other sources in these posts.
Really interesting and informative post. Could someone explain to me the difference between the 5966 and the 5967 reference? I see both 18k pink gold, with the original price of the 5966 slightly higher. Thanks.
The difference is simply the style. The 5967 has straighter lugs with a broad facet while the 5966 has curved and stepped lugs. Maybe the price difference has to do with the amount of gold, manufacturing process, or supply?
That makes sense, thank you! Do you know which one is more sought after today?
I do not think that there is much of a difference today. If you can find a nice example of either reference, it will be of interest to Longines collectors.
Thank you. I like the movement a lot, it is so beautiful. I see prices in a range of 4k to 9k, hard to tell what a right price is to buy.
