Early Polerouter Sub Discussion
Looks like the real deal too me, dial might have got wet at some point, need better pics and or without crystal.
Removing the crystal is beyond my skillset. I am also very hesitant to polywatch the crystal. I am currently researching service options.
I think the case looks legit, dial looks legit too.
Be careful with the crystal, if i remember well they are hard to source as the require a ring.
Depends if the crystal is signed. The signature is usually on the inside of the crystal so won’t be damaged by polywatch. When I got my sub the original crystal was split so it had to be replaced, although there are a few new crystals about the are stupid money I think I was asked $500 for one. I worked out that the nearest GS crystal is a pa484 that can be found for $10 and needs only a little bit of sanding to fit nicely.
Thank you, That is very helpful information. I will post pics again if I clean the crystal or can get an unobstructed view of the dial.
