Come across a beautiful 105.012-64, too good to be true...
Do you think you could get more pictures?
Showing the dial and and case from different angles?
and is it possible for you to see it in person before you decide?
Does the watch come with an "Abstract of the Archives"?
This would be for me the "conditio sine qua non" to buy it or not.
If the movement wouldn't be right one for a 105.012-64, I would stay away.
Note: To find the right band with the right end links from the right year, will also be a hard nut nowadays.
The bezel and the dial look ok for me....
Cheers
No Abstract of the Archives. I definitely have to check the movement before I buy it.
As for the band, yes, it will be a hard nut. but i wouldn't mind to wear it with a Forstner band. I used to have one, it was very well made.
Yes, I can view the watch in person. But the seller is asking $11600 for now, don't know whether it worth a F2F meet up...
I concern mostly on the lume. As I shared, I never seen a watch of this age with no blackened lume on it.
This is entirely untrue. It’s not easy or common but 60’s Omegas with untainted lume certainly do appear. The lack of black marks may warrant further investigation but in itself is not an indicator of a relume.
Thank you very much for the info!
Do try and get more pictures??
And also on the movement?
And ask for the serial nr?
Have you checked the sellers references??
Not yet.
I found this watch on a local second hand marketplace. We can meet up F2F to deal.
Offered $10000, did I offer too much?
iI could be high, low or correct?😉
You need to see the movement and try to get the serial nr.
When you are dealing with this level of money, its not time to gamble...
And the seller - is he a dealer or a private person?
I believe he should be a private person, but he got quite a number of very scarce watches to sell.
Orig JB Champion is findable would look good on this IMO
Do you have any more questions about the watch? Seems you now just need to decide whether you want it and if so, how much you’re willing to offer.
Does it look like a relume? I'm wondering how many of u would like to take this watch for $10000...
You're asking hard questions based on bad images and partial information.
Do you have Movement Photograph and serial number?
Serial should be in the 22.826.XXX range.
