Hey guys, is this a joke? Replacing air with helium won't affect the mass of a watch as stated the OP...
Am I missing something???
I don't have a dive watch. Would adding helium to my regular watches make them noticeably lighter?
I have a friend that was a chain smoker, he unfortunately had one of these faulty valves in his Omega PO "Hindenburg limited edition" and it blew his whole hand off. Now he wears a non helium watch around his neck. Looks OK.
Here's an approximation:
Density of helium: 0.18 kg.m-3
Density of air: 1.28 kg.m-3
Difference: 1.1 kg.m-3
Case volume: 4 cm diameter x 0.8 cm = 10 cm3
Assuming the helium completely fills a watch case with 5psi pressure above atmosphere (or 1.3 atmosphere), we have 1.1kg.m-3 x 1.3 x 10 cm3 = 14 mg, which is over a thousand times smaller than stated above.
I added mercury to this
And now it has the quality feel of my Speedmaster! It went from a puny 11.3 g to a robust 27.8g! Only problem - if you consider it a problem - is the conductivity of the mercury shorted the battery and fried the electronics...
Okay, I'm calling total BS here - helium is NOT flammable. It was hydrogen that cause the Hindenburg Disaster. I know this because I studied the accident as it was the other biggest disaster to befall NJ on May 6th.
Don't make things confusing with facts.
That's what you get for owning a battery powered assault on horology. 😁
Dude, I think you should have chosen another Noble Gas instead of krypton. Neon is the much closer in weight to helium so it would have less chance of damaging the balance & pressure. Plus, it would give your watch a healthy glow.
