Big problem with helium escape
A question came up in another thread about the best grease for a watch's HRR (helium retention ring):
Don't forget to mention the HRR (helium retention ring). If the HRR isn't properly greased, the seal could be compromised.
rumor has it that Astroglide is the grease of choice for the HRR...any truth to that?
Don't know. Maybe we should as in that thread.
Do any of our watchmakers or members have any insight they'd like to share? Also, is there a generic version of Astroglide that might save a little money?
Thanks!
You can get ID lube...this should grease up all of WUS HRR.
Do Rolex and Omega HRR require more or less lube than a microbrand HRR?
prod_8036946515
Thanks!
I refer you to my Avatar. When you see how much money you can save you might also want to smear some on your teeth. I hear it helps to achieve that Rolex smile.
I have not read the whole thread, sorry. But the volume of a watch case is fixed. If it was evacuated of all and any gases it would be lightest. Less than a gram less compared to any gas you could put in there. If you then add back Any gas, including He the weight of the watch would only increase. The more He you add the heavier the watch would be. But again, even at 1,000 PSI it would not add a gram to the weight to the watch.
In fact, if you pressurized air vs He to the point of liquefaction the He would actually weigh more but still less than a gram likely.
Ali
Ali
Hi Ali - you are aware that this thread is a joke, right?
Lets not forget the implications if you get a helium build up and cant release it ..... if the bracelet clasp sticks as well you could be seconds aways from bad times......
Calling this thread and the whole helium escape problem a joke is just not right. This is a serious problem that should not be taken lightly - as helium.
