X-33 Battery change
Did another DIY battery change. And this time took a peek at the 1666 movement. 馃榾
And everything is tested and working
Did it on my X33 and Skywalker the other day, easy enough with the right screwdriver.
Depending on what you鈥檙e willing to try, I appreciate that you gave it go.
It will be fun when its time to replace the battery on my Z-33. So far I have seen nothing regarding a DIY on Z-33. but I expect it to be similar to a X-33. 馃榾
I came to read this as my X-33 first generation was giving the battery dying signal this morning. For any readers in the UK, I took my watch to the Omega boutique on Oxford Street in London and was quoted 拢40 to replace the battery only, and potentially 拢100 (i.e. an additional 拢60) to carry out some further minor tasks that may be necessary (and I must confess to not being wholly across the detail of them). I was also clear that I wanted the watch pressure testing to its specification. I have authorised work up to 拢100. After reading everything above, it was much simpler and cheaper than I was expecting. The 拢40 seems in line with the $60 quoted above. As I bought the watch second hand, I have no idea of its service history, so I have no idea what will come back. I will also say that I would not regard spending 拢100 every couple of years on a machine that cost me 拢1800 as being excessive. But that's a personal view with no real objective justification.
I expect the watch back in 2-3 weeks, as it is sent to Southampton.
I just thought the up to date info on the cost and timing of a replacement battery at Omega would be helpful.
Not quite the same complication, but my 23yr old Seamaster 300m Quartz hasn't ever been back to Omega , a service centre, or a dealer - I've always changed the battery myself, with a little silicon grease and a new gasket every other battery. Probably saved many 拢hundreds in that time. My decision wasn't based on money saving, more about not giving the watch up for weeks at a time.
Thank you for sharing this; you may have just swayed me to go for the X-33 after all. I get to London often enough that using UK boutiques to do battery swaps and minor servicing is entirely possible.
Mine was an impulse buy whilst shopping for a Moonwatch (eventually, it turned into an Apollo 8). I have loved it. It is very practical in my job as a lawyer where recording time is a key part of our day. It's also unusual enough to generate interest. I can only speak for the first/second generation, and not the latest incarnation, but it's been ultra reliable as well for a 20 year old digital quartz watch.
I thought I would update on my battery replacement. In summary, the 拢40 I was quoted was an error. Turned out to be 拢155, including reseal, new crown, pressure testing.
Unfortunately, the watch then came back without anything that required sound working (alarm, countdown, beep on pressing a button). It has just returned today having allegedly had a full service, and now appears to be working. What I found surprising is that I'm entirely unclear as to what actually happened or what work was covered in the "full service", guaranteed for two years in circumstances where I'd handed the watch over to Omega working and it came back not working. I had understood that "full service" on these models basically involved the replacement of the movement altogether. I will be thinking very seriously before letting my Apollo 8 or indeed the X-33 go to Southampton for servicing again.
I should make clear that I was not charged for anything beyond the 拢155 for the work the watch originally went in for.
Anecdotally, it has been reported if the case back is installed incorrectly, the sound is far less audible than the advertised 85dB. I've never heard of your situation before though.
Yes, I can confirm that with my DIY battery change 馃榿
Maybe they screwed up somehow. But a brand new movement is USD$500. So if they put in a brand new movement, then you lucked out on this one. 馃榾
