Vintage seamaster help pls
Hi all;
Does anyone know anything about this model of vintage seamaster? It was my grandfather’s, likely from late 50s, thanks
Hi @claraxx
Welcome to OF.
It’s generally customary for new members to introduce themselves but, that said, it looks like you have a nice watch.
Better, sharper, larger photos in good light would help but, based on your photo, it’s possibly an early 1950s Seamaster model 2577 with a 351 bumper automatic movement.
Again, in the absence of better photos, it looks like the dial may be original which is a big plus.
Don’t try opening the caseback yourself - unless you know what you’re doing but, if you send it for a service (and it probably needs one) get the watchmaker to photograph the movement and inside caseback.
Don’t bother going to ‘the guy in the Mall’ who replaces batteries and, if you post the area in which you are, someone should be able to recommend a good and reasonably priced local watchmaker.
So, post better photos.
If I’m right about your watch, this is my 2577 cal 351 gold-capped bumper.
The watch can be definitively identified (and approximately dated) using numbers on the inside of the watch. So if you have it opened, please take good clear photos of the movement and the inside of the case-back, clearly capturing all engravings and numbers.
That said, any photos you can show right now would be helpful, e.g. of the back.
It’s definitely not an automatic, as the word “Automatic” is not on the dial, which I also believe to be original.
@Dan S is correct, we’ll need more information to help.
gatorcpa
Its not a 2577 for the reasons stated above. More likely model 2761 with calibre 420 which is manual wind. If so that would date it around 1954-58 or so. The bowler hat crown is correct. These didn't always have a clover leaf crown.
