Very nice Original Ed White on EBay..........or is it??????
I have a question about this point. Is it mandatory to do a service or just a "tuning" (réglage in French) is enough ? Does it imply a complete service?
This problem itself is not an indication that the watch needs service, however it's usually only watches that are in need of service that have it. To repair this problem alone, the hands and dial have to be removed, and either an adjustment is made, or parts are replaced as necessary.
The first thing I do after completing the assembly of a freshly serviced movement is to mount an hour recorder hand (no dial at this point - I line the hand up with something on the movement as a reference) and start the chronograph, let it run for 10 seconds, then stop it, and let the watch sit. If I come back later and the hand has not moved, I then proceed to install the dial and hands, and case the watch.
Many thanks for stepping forward and declaring yourself as the seller. Much appreciated.
I hope you don't mind but I have a question in relation to the pictures that are posted. BTW the watch does look wonderful.
Are you able to advise if your understanding is that the case back and case has been polished?
Not a problem if they have. At times it is difficult to compute what one sees in photographs, as to how they look if one were seeing them in real life.
This doesn't detract with the positives of the features that the watch displays, but, merely looking to complete the picture. (The lume is understood).
Case and bracelet are polished of course ! It is obvious I guess. I also understand some collectors prefer a unpolished case and I respect that.
As for the not so arty photo, there are plenty of them on the auction. The "money shot" of the dial is the last photo.
Ok see it now thanks. No lume but nice watch nonetheless. A bit shiny but seems to be plenty case left.
Where did it go now? Better offer outside Ebay?
