Universal Geneve Watches On Ebay
The fact that HPC is on the dial. But, seriously, we still don't know what HPC means.
I agree
Although I have read multiple discussions suggesting the HPC as indicating a high performance chronometer. Asssociated conversations suggest they were certified at the Institutes in Switzerland, Saxony or Besancon -- all of which I believe were only established in the early 70's..
Anyone ever seen or tried to get a duplicate certificate?? Could it be a marketing marking indicating a High Performance Chronograph?
As a reference, for Omega Marine Chronometers you can request and get a duplicate of the original cert if you're so inclined
I agree
There are also time only watches marked HPC, so "Chronograph" is out.
bgrisso-very good point; I obviously didn't consider that-
A little more info on certification process prior to 1973 (Wiki):
Between 1961 and 1973,[22] “a chronometer [was] a precision watch, which [was] regulated in several positions and at different temperatures and which had received a certificate [from the (“B.O.)]." Collective certificates, rather than individual certificates, were usually issued. The 1961–73 standard required a mean daily rate in five positions of −1/+10. In 1973, the C.O.S.C. certified a specified daily rate of −4/+6 sec.
In consideration of the today's manufacturing prowess /equipment sets one might wonder why there has been no tightening of the performance requirement.....certainly a good ride for some....
Two factors rule out the C for Chronometre explanation, at least for this example.
1. There is no sign of the movement being numbered.
2. The movement is inscribed "Unadjusted".
Even C for Certification seems unlikely given the apparent absence of any identification like a numbered movement.
This is an interesting one: https://www.ebay.co.uk/itm/304042207162?hash=item46ca53e7ba:g:WxAAAOSw5Yxg0kJQ
Another HPC. Bit of a strange reference: 312201 and serial 1320903. Movement: 100931. Also a P added?
However: unfortunately there is not much to be found on google anymore but some time ago serial 1.320.937 with movement 100.800 and also marked HPC appeared on Ebay (
https://www.ebay.co.uk/itm/Universa...=true&nordt=true&rt=nc&_trksid=p2047675.l2557)
First time I see 2 close serials of the same reference marked HPC.
https://www.ebay.co.uk/itm/Universal-geneve-Exclusive-HPC-/154285793733?hash=item23ec2661c5:g:qB4AAOSwObNf5yaH&nma=true&si=7cJ0H931yoFjJpIZ55Y3%2BM0BJ7Y%3D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557)
Does that case back belong on a watch with chromed case?
This one seems to be gold plated (or is it 18K? I can't tell).
Good question. I think it is plated
Hey guys! This showed up on my local market from Romania! If anyone is interested here, I can put you in touch with the seller! No any connection or benefits! Is asking €1k! But there is a piece missing, so I am sure he will be open for discussions!
TBH this part is close to impossible to find... at least if you are looking for a 45min counter 8270. A guy in Germany is reproducing the part for 30min counter, no idea how well it would fit a uni-compax.
looks like that missing part is the very least of the problems
thanks for posting and interesting info on the second example you found (the ebay link does not work for me, so I can't see anything)
Hard to say what is going on here since the caseback does not match the case, or vice versa. No way to know if it's even a UG case. But still, interesting info just on the dial and movement.
Too bad the earlier Ebay link is not available anymore.
Interesting to see that the movement is numbered.
