Posts 202 Likes 102 Speedy2254 ·Mar 27, 2020 Can anyone recommend a 20 to 16mm bracelet that would fit & look good on a 2254? Pics please, thanks.
Posts 2,326 Likes 1,887 VetPsychWars ·Mar 27, 2020 Its original "Speedmaster" style bracelet is that. I believe it's 1610/930. Tom
Posts 202 Likes 102 Speedy2254 ·Mar 27, 2020 VetPsychWars Its original "Speedmaster" style bracelet is that. I believe it's 1610/930. Tom Thanks, I'll look it up.
Posts 3,425 Likes 6,593 fskywalker ·Apr 4, 2020 Yes 1610/930 is the one that tapers to 20 to 16. The other bracelets that fit are the Bond version (1504/825) and the one from the Aqua Terra 2500 series
Posts 10,807 Likes 16,816 padders ·Apr 4, 2020·Oooo subtitles! Nope. 1610/930 tapers to 18mm. I think some of the 1990s Moonwatch bracelets did go down to 16mm. 1497 & 1498 maybe.
Posts 3,425 Likes 6,593 fskywalker ·Apr 4, 2020 padders Nope. 1610/930 tapers to 18mm. Stand corrected!
Posts 795 Likes 1,159 Pazzo ·Apr 6, 2020 padders Nope. 1610/930 tapers to 18mm. I think some of the 1990s Moonwatch bracelets did go down to 16mm. 1497 & 1498 maybe. Isn't that the clasp you're measuring that is 18mm. So, I guess that the actual bracelet ends up to 16mm. I stand to be corrected though.
Posts 10,807 Likes 16,816 padders ·Apr 7, 2020·Oooo subtitles! Pazzo Isn't that the clasp you're measuring that is 18mm. So, I guess that the actual bracelet ends up to 16mm. I stand to be corrected though. On the 1610/930 the clasp and bracket are the same width. 18mm. See the picture above. The removable links are 18mm wide.
Posts 795 Likes 1,159 Pazzo ·Apr 7, 2020 I couldn't really tell from the above image, tbh. And as I said, I stand corrected. 😀
Posts 10,807 Likes 16,816 padders ·Apr 7, 2020·Oooo subtitles! Pazzo I couldn't really tell from the above image, tbh. And I stand corrected. 😀 Fair enough, I knew what you meant, on the newer models with adjustable clasps, the clasp can be 2-4mm wider than the bracelet. Not on these.
Posts 491 Likes 2,132 zoohannover ·Apr 7, 2020 If some rattle would be okay, maybe the 1171 bracelet? A fellow member tried it on his 2254 and posted it here: https://omegaforums.net/threads/1171-the-versatile-bracelet.109401/ Edited: Apr 7, 2020
J Posts 113 Likes 128 jeelan ·Apr 7, 2020 I didn’t think Omega did a “modern” bracelet that had a 4mm taper do they? By modern i mean anything with a 1120 or later calibre....
