Speedmaster pushers: how stiff?
I'm sure you would do a fine job hosting, Bob...
Thanks. But if I become similarly afflicted, won’t I be dropping the mic?
This joke has...
Is it? How so?
I'll be honest, in all the years I've been on watch forums, this is the first time anyone has brought up the issue of the start and stop forces being different as a problem that I've seen. Pretty much all discussions surround the difference between the feel of cam and column wheel chronographs. [...]
TL;DR : my super rough wild ass guesstimate is the systematic effect of uneven pusher force might be on the order of 20ms, and might thus matter for the fastest mechanical stopwatches, but not for our chronographs.
Long version:
Well, there's always a first time...
Hi Al, I was thinking more of short distance running, 100 to 400m, where you definitely need 0.1s (or better) precision.
I agree that this issue must be completely irrelevant for applications where 1s or 0.5s precision is good enough. (I hope you weren't pushing those poor workers for every tenth of a second...😉)
But for sporting competitions, you wouldn't want to introduce a systematic time offset because stopping happens faster than starting (assuming same speed of 'trigger finger' force buildup) and depends on the watch used, which is why I assumed that this is a solved issue.
It is already a while that mechanical stop watches were used for high profile sport events, but mechanical watches to time to 1/10th and even 1/100th of a second did exist. I found a nice article on the development work Seiko did for the 1964 summer olympics, but no mention is made of the trigger forces. It seems that at about that time the switch to electronic timing systems happened.
NIST has a document on stopwatch calibration, but they don't mention this issue either. (They do talk about reaction time.)
So then I started looking at physiology papers, but it's really not my area of expertise, and I was ready to decide I'm not that interested and to give up, when finally google decided to give me some graphs and numbers (it's all about the right search terms...). From the little I have looked at it seems (I could be completely wrong) that a muscle might take on the order of 200 ms (give or take 100ms; I used the search term 'isometric force vs time') to build up its maximum force, so assuming I can pull 50N (5kg weight force) using my index finger muscles, then a variation in force of 10% of that (5N = 500 gram) corresponds to 20ms. (The force buildup is apparently not linear, but this is good enough for our purposes.)
So what does that mean?
20ms (even with a large uncertainty factor, say 2 or 3) is small compared to variations in human reaction time.
As an offset over many timings it could matter for 1/100th second stopwatches.
20ms does not matter for time intervals measurable with our chronographs. If the effect were ten times larger, then one might be able to start seeing differences between different watches.
I'm still miffed though. They engineer cars so that closing doors sound pleasant; why can't they engineer watches so the pusher feel is even?
This thread reminds me of the "Princess and the Pea" story. I can't believe what I'm reading in this thread.
This joke has...
This whole thread has become a
but somehow I can't look away.
My original question has been answered perfectly, but please do carry on 😁
Long version:
Interesting.
But a study centred around the use of the thumb rather than an index finger to actuate the pusher would yield a more accurate result.
Taking into full account the elements around Bio mechanics, leverage and strength and all😉
Interesting.
Not necessarily. I think most people use their index fingers to actuate the pushers when wearing a chronograph, and even when being held in the opposite hand, so it’s kind of a moot point. Further, the DIP joint of the thumb would be held in quite a bit of flexion to actuate the pushers, as to make the thumb flexor biomechanically inefficient Further, the sensory receptors in the index finger are denser, and therefore more sensitive, than the thumb.
I love this thread! Did not quite expect the turn it has taken
Well thats good cause my input wouldn't be of much value anyway. My top pusher was always really tough and it concerned me up until the day it completely stopped working and I sent it back to omega. I was hoping to get it back and maybe it would be smooth but I guess thats not gonna be the case after reading all this feedback.
Update: the IWC boutique in Chicago also sells Lange and Panerai, so I had to try a few of each. I am happy to report that if you are spending $75k on a Lange, you will get very even smooth well defined chronograph pusher operation. Below that, it unfortunately seems not so much.
(I didn't bring my scale, so I do not have numbers for that Lange. 😉)
Using my Speedy Pro for timing engine bursts before entering Earth’s atmosphere it struck me that the tactile quality of the start/stop pusher on my watch is not particularly nice.
I have to push really hard before the chrono eventually engages. It’s a big, sudden clunk rather than a gratifying mechanical click. Hard to describe in words I guess, but I wouldn’t really describe it as pleasant - even though the stopwatch itself works reliably enough.
This is my first chronograph, so I can’t really compare it to anything. How stiff is the pusher action on the Speedmaster Pro supposed to be?
Would you rather it start or stop accidently after a small bump?
I’ve yet to successfully activate the chronograph on my Speedmaster 😁
Personally, I do around 100ish re-entries into the atmosphere per year and the pushers are getting smoother with use.
However Chris ( hartfield) advised me to activate pushers before hitting the ionosphere, especially in the Soyuz. He got a timing error once and then decided to stick to the gen 2 x33.
Each one his own I guess.
Safe flights 😀
Safe flights 😀
I think you mean Chris Hadfield....
Since the pushers are identical in every way between the top and bottom,. I'm not sure this has any credence.
Well, although the top pusher is mostly used more than the lower, looking at NASA photos, it's always the lower pusher that's gone missing 👎
I know you whole thing is NASA, NASA, NASA, but that is a very tiny representative sample of Speedmasters used by them and other space agencies...not sure it's really indicative of anything in particular.
