Recommended Vintage OMEGA WATCHES (only) On EBAY (NOT for Inquiries)
I thought the same thing….
It’s meant to say gold-capped as you can see it has a gold bezel and steel back, and by sub seconds dial I’m referring to the fractions of seconds used in the outer seconds track which is uncommon in a De Ville
That one really went cheap for 14k
I kept missing good 14k De ville 🙁
This is one of the cleaner C-cases I've seen from Closer and a decent price. Bracelet has 2 (Edit: not 4) removable links which is pretty good and movement looks really clean.
https://www.ebay.com/itm/266322842521
Bracelet has 4 removable links which is pretty good and movement looks really clean.
Just a heads up that only two of those links are removable. Assuming all the other links are there, that will fit a 6.75 to 7.0 inch wrist with one adjustment hole on the clasp to spare. 😀
Thanks Ryan. Maybe I would know that if I ever got to wear my watch. 🙁 I assumed all the pin ones were removable. Couple more days...
This one’s very interesting, a Constellation Megaquartz Marine Chronometer in great condition and in good working order according to the seller. I’m curious to see what this ends at, as I haven’t seen a good running example go no reserve in ages.
https://www.ebay.com/itm/166214591070
This is a really nice and clean 9KT gold Seamaster De Ville Cal 601 with box and papers that looks like it’s never been worn.
https://www.ebay.com/itm/155642318312
4 hours left on this Seamaster De Ville
