Recommended Modern Omega Watches On Ebay (not Inquiries)
2 hours left on this
That bizarre description must have cost the seller at least $500.
Mate rat droppings is in no way the most disgusting thing I’ve found infesting a used watch and in this case it’s just the box so that’s a win for the buyer imo 😀
Bond Spectre LE with full set in nice shape going no reserve
wrote about these here: https://stories.omegaforums.net/how...edition-became-the-hottest-bond-watch-of-all/
https://www.ebay.com/itm/266339531481
This Spectre LE full set goes off later today, very cheap so far
img_8079-jpeg.1637065
Speedmaster ‘57 on bracelet going no reserve in the UK, one of the most attractive of modern automatic Speedys
https://www.ebay.com/itm/126030134640
Not sure why the seller has "Mechanical (Automatic)" in the description. The most recent '57 uses Omega movement 9906 which is hand-wound (Omega states they did this to get a slimmer case height of 12.99mm vs the trilogy '57 that was around 16mm high). 9906 is a co-axial column and wheel movement. This seller doesn't have a picture of the rear of the watch, which would clearly show this. The ref that the seller has listed uses the 9906, and not the 9300. I admit, however, that I do not know if the current 2 dial with date also had a prior automatic version using the 9300.
It's a beautiful piece and very likely one that I will eventually own, either in black or blue, so thank you for sharing the listing, @dsio .
