Recommended Modern Omega Watches On Ebay (not Inquiries)
Figured that was coming. It closed at $4500 USD with no action at all.
Its interesting how much prices have softened, especially for this early version with the non-micro-adjust bracelet
how did that happen? There was no reserve so it seems like the high bid which was about 4500 should have won it
My guess is the seller wasn’t happy with the final amount.
2 hours left on this now
Probably not catching a lot of attention because the seller seems to be using a case reference and not the model reference. Also, is it titanium? I thought they were all marked "TITANE" on the case back.
Some Seamasters do but these ones don’t so it’s a bit of a mix. The best way to tell is the regular steel bracelet has an endlinks marked 825 off to the side of the endlinks while the titanium is stamped TI-825 and has different markings inside the clasp.
Here’s an example below
Nice clean 18k solid gold DeVille Prestige Cal 2500 going no reserve
https://www.ebay.com/itm/126000993988
This 18K De Ville Coaxial goes off in 10 hours, only 2k at the moment.
img_8003-jpeg.1629888
Previous Gen Cal 1861 Big Box Set Speedmaster Pro Moonwatch, these are a bit of a sweet spot on the used market or a Speedy right now i you don’t mind the older bracelet.
https://www.ebay.com/itm/275948585927
