Omega Speedmaster Soyuz bracelet 1168
Hello, I have a Omega Speedmaster Soyuz 1168 vintage bracelet, that I´m about to trade for a 1039 Speedmaster bracelet, is it an even trade ?
Hard to find a value online, I don´t want to embarrass myself.
Thanks
//Fredrik
No I wouldn’t think that is even close to an even trade. The 1168 is much more rare
Depends which 1168. The one with the wider final link and correct end links or the more commonly seen 1168 used on various Admirals etc.
You'll need to measure the width of the final links then do some research to see which version it is.
The slimmer, more common version is worth less.
In all honesty I can't see someone swapping a 1039 for one.
That looks like the 20mm. If so it’s not a good deal for you at all.
Yes, It is the 20 mm bracelet. could you give me some kind of figure😉
The only one I can find is on Chrono24, its 7000USD 🤨.
i've seen 1168s struggle at $500 and others languish at $3000+. Hard to gauge. Technically, the 1168 is only good for the Soyuz speedmaster (as you probably know), but was also used on Seamasters and other non-speedy references. On it's own, it's hard to nail down. I bought one a couple years ago for about $300 while 1039's were already pushing $1000.
