Omega Constellation
168.045 still has a different bracelet interface, doesn't it? It seems to have the center 'tang' but otherwise female bracelet connection based on the examples I can see. But yes, no that you point it out, the above likely DOES have a
168.045 still has a different bracelet interface, doesn't it? It seems to have the center 'tang' but otherwise female bracelet connection based on the examples I can see. But yes, no that you point it out, the above likely DOES have a missing bezel.
Thank you both. I also noticed the watch seemed to have no separate bezel when I first received it. However, I agree that the bracelet interface doesn't exactly match the examples of ref. 168.045 that I've found. Could this be another reference using a similar case architecture and bezel?
I didn't look at that, but yes you are right. That one has two slots with a narrow middle part.
Maybe the OP can provide the numbers on the inside of the clasp...
