Omega Constellation Automatic Chronometer Band
Th
I have three cal 1250 Omegas. To change the battery, you must unscrew the caseback. I use a watchmaker's caseback ball.
You'll then need a fine edged screw driver (about the size used to adjust the ear pieces if you wear glasses).
You then loosen the battery holder screw, remove the battery and replace it.
Sometimes it may take a little bit of adjustment to get it sitting right.
At least that way, you’ll know if the watch is working correctly or not.
If not, post where you live and someone will be able to recommend a private watch repair that specialises in this sort of watch
Thanks for the help I replaced the battery, but it did not help
