I get that you wanna sell it and that you believe some publicity might help. But if you wanna extract maximum € from the sale, listen to what people said in your first thread. Go the distance, have a watchmaker pop of the case back, take proper pictures of the inside of the case back and the movement with the rotor in different positions, so all parts of it are depicted. Move the hands away from any writing on the dial and take some high resolution pictures of it, from straight on, no angle. If you don’t have a decent camera, ask some friends - even a modern iPhone will be sufficient. People here might then be able to assist with an estimate of what it might be worth, and the pictures will help you achieve a higher amount in an eBay auction or on C24, for example. Reposting the same pictures and the same initial question, though, won’t get you there.
