Old Skool Omega Bracelets w/pins & collars...
Pin gets driven out in the same direction as the arrow -but- how do you put it back together -- opposite direction or same? Any orientation on the collar?
Can someone detail the process for me?
Just learned they are called pipes not collars.
Keep the responses rolling in though, extremely helpful.
SC1 SC1
When you approach a one way sign with an arrow pointing a certain direction, do you go with the direction of the sign or against it? 😁
Depends on whether I am in reverse or not.
All I know is that they were forged by Lucifer himself.
They go back in the direction they came out and they are tapered or flared- that part goes in last with resistance- you may need to lay it on it’s side and press firmly with a flat object. I use the side of my small pliers that I use to pull them out.
And if you think these were made by Lucifer, the baby spring bars used in the 60’s era BOR’s were his masterpiece
It really depends on the bracelet. On some it doesn’t really matter, where the pin is the same diameter for its entire length. As mentioned, if there is a head on the pin, that comes out first, and goes in last...
Didn't I say precisely that in a different thread a while back? Maybe I didn't. Sounds like some shit I'd say. Anyway, I'm suing you for verbal copyright infringement. ;-p
@Archer Speedmaster Reduced V2 bracelet (V2 meaning - sapphire crystal and clasp with pushers).
SC1 SC1
Those will be straight pins.
