Let's see some 30mm manual wind omegas
Royal Air Force 1942, movement 30T2SC. Older picture.
I sometimes wonder if some of us has issues with wearing a non-incabloc watch in daily use? My watchmaker says some of the balances even risk damage in mail.
I can’t really say because I’m a lady and I work at a desk so I’ve never had any problem with daily use. I don’t usually bang watches- the only times I’ve broken one is when I have dropped them accidentally, twice unfortunately— and that did not happen in the process of wearing a watch regularly, rather in the process of pulling out the watch from storage in one case— and in manipulating the movement stupidly during inspection at my watchmakers. As a result of which the needed service also required a balance replacement. Never again.
I think a lot of us have tried that. My watchmaker, always a know-better, tells me: "have the watch in a drawer or on your wrist." :whipped:
My RAF Omega from 1942 in Stainless steel says hello. Older pic as well but i still own it👍
My other two i have is a cal 265, ref 2639-4 and Omega Suverän cal 30T2PC, ref 2400-2
Is there a reference database? Cant seem to find if my 13322 has any more of a reference than that? Is it 2705? Also if I request an extract of the archives will I get much as case was U.K. and assembled here?
This is a Dennison case reference, they were a local market product for the U.K. To my knowledge the English case-maker Dennison imported Omega movements and cased them in (“Dennisteel”) cases.
Thanks yes - do you know does that mean no ck or ot reference?
will extract of archives deal only w the movement supply?
There are a huge number of variations. There were a good number of 9ct and some 18ct gold as well as steel.
The reference is Dennison’s own, to my knowledge the 13322 was used to case Longines movements as well. I think Omega can only provide you with information based on the movement serial number. This is the best answer i can give you.
While there's no doubt that watch movements that don't have shock protection on the balance are more vulnerable to broken staffs, in everyday use this usually isn't a problem. I service a good number of watches without shock protection, and broken balance staffs are still not a common problem. The bigger issue is dropping the watch, but unless you really smash it hard into a door frame or something, the staff is likely to be okay when wearing the watch.
Note that I have shipped these watches all over the place as well - not one has ever arrived with a broken staff. The only way that is a real risk is if the watch isn't packaged well, or if the cargo plane goes down...
Thanks bboz - I did look at the Dennison longines as well - the cases are apparently identical - both Omega and Longines 12.68z fit
I'm a fan of the two-tones from this era. Here's a 1949 cal 265, bought in New York City in 2012.
I inherited this watch from my grandfather who got it in 1949. As far as I could gather it is a ref. 2367, 30 SC T2 RG with a cal. 281 movement.
It keeps exact time but as it has not been used and running or serviced for probably 40 years, I brought it in to a watchmaker to have it disasembled and cleaned. The seconds hand is not original, I was told and will be exchanged. I am looking forward to getting it back in a few weeks time.
I am very happy with it!
You should be happy with it, it’s very nice indeed. Enjoy 😀
That watch is a tough act to follow. Welcome to the Forum bernstein.
Here's a new 30mm manual wind acquisition, a '62 vintage Seamaster with a 286 movement.
Seller's photographs
