Let's see some 30mm manual wind omegas
Even a 2639 deserves a gator strap.
This is my first post on here, I have just obtained this little beauty, any ideas of age?
Not sure this is the right thread for your watch. It looks to be an early waterproof model from the early 1940’s. The movements in these are not the 30mm series, but instead the cal. 26,5 series.
If you post this as a new thread, you are more likely to get responses. BTW, I think it’s a very nice piece.
gatorcpa
gatorcpa
Hi Gatorcpa
Same case style ( 30 mm movement used a larger diameter 35 mm ) incomparison to the 26.5 movement version ...
Just a FYI !
Good Hunting
Bill Sohne
gatorcpa
Te calibre is a 30T2 so I assume it is a 30mm?
Hi
Yes. 30T2 stands for 30 mm movement second transformation.
Great watch loves these !
Best
Bill
Heavy dial patina, wrong service crown, scratched crystal. I was contemplating using it for parts but with an old no-name flatlink bracelet it came alive! And when missus says it looks the part, it is deemed a keeper.
She was talking about you, brother man!
My 135.007, with the Cal. 286. Still amazingly accurate (+2 seconds a day) after all these years.
gatorcpa
⚠️ Possible franken entry!
(moved to new separate thread)
These two early 50s pieces make an interesting pairing. Ref 2890 (left) and 2640 (right).
Two beauties!
Spectacular dial on the 2890, a work of art!
Thanks for sharing.
My 2639 says hi to her central second sibling!
It's really fascinating how many different dial variants for the 2639 are existing. This is the first one I've seen that has a “Swiss Made” signature with a space between the two words.
I haven‘t managed to find an original and affordable 30T2RG in a steel case. I‘ve settled for this black 30T2 for now.
I paired it with a non period correct 7077 bracelet and #7 end links. Don‘t ban me for this 😂.
