Help Me Pick?
Don't disparage yourself like that friend... you'll always be a jag-off to me.
Jerkoffs are a dime a dozen, you & me -- we are special.
Special bus Special !! 😗
I would go for the Forstner Komfit. Just like them:
If I were, standard width or wide? I'm going to assume that the fellas in your photo were sporting the standard width.
Perlon looks good on a Speedy Pro. Should set you back about $30, save the rest for next month.
Yes, I think these standard ones, with so called straight ends.
Truth... but she's a RN and therefore used to being around liars, thieves and swindlers.
and that’s just the doctors …
It's heavy duty high quality polished stainless steel wire, woven into man-sized links, not like fancy delicate Milanese fashion stuff.
It's infinitely adjustable (for initial sizing) and is secured by a seat belt style clasp (the same thing used to retain millions of drivers and passengers).
It's what real mean wear 😉.
what Milanese bracelet is this?
Also to op if you were thinking of Komfit, I would recommend wide and horned. Wide to me looks better even though not as traditionally used as the thinner one. Horned looks better as it has less empty space in between watch.
