Gallet chrono...thoughts?
Reasoned arguments backed up by evidence may get heated at times and then consensus emerges. I think the UG Forum here does that well as does OF. If we were all to shrink from disagreement, this would be a less interesting place.
Agreed, Larry,
Below is an example of a Gallet watch with an EP42 movement that, according one who is an expert, is a 1939 watch, but with an original 1945 dial:
"SWISS" looks pretty amateurish . . . and what should we make of the bleeding of the ink on the old-style Gallet numerals?
Sometimes the angle of a shot and/or possible distortion brought about by a "lens effect" traceable to crystal irregularity results in a questionable effect . . .
. . . and sometimes the original dial may have been printed with flaws or may have otherwise aged poorly.
And sometimes its a redial.
I know very little for certain myself. I'm mostly here to learn. 馃槈
Agreed, Larry,
I don't have concerns about that dial. The fonts are consistent, ticks are even, sharp, and square, etc. Any flaws are very minor, and plausibly related to defects in the crystal.
I don't have any concerns either. 馃槈
In fairness, if that photo is the best we have to look at, it is not really good enough to state anything to a certainty.
The angle of the shot and the crystal are not much help here, but no two of the three "S" characters in the word "SWISS" appear to be identical.
The "A" in Gallet is asymmetrical and likely distorted by the crystal and the T seems further away from the rest of GALLE T.
But the watch looks good to me too.
The ticks are much more even then as seen below:
I know this couple years late, but hoping for some help. Trying to get an estimate on value and maybe some information on a Gallet 14k watch.
Nice to see one with the case intact. Most of these were scrapped for their metal content.
The movment is Landeron. Probably a 51. A lower end chronograph movement mass produced in the millions.
As often stated rough value can be estimated by looking at closed or ended auction listings.
I have around a dozen movement most of what do not have cases. White metal plated cases are the most common. Stainless cases the most desirable. Gold does not really work well with chronos what were working watches. Gold filled is probably the least desirable.
There are some threads here on the successors to Gallet Use the search term site with a colon followed by omegaforums.net and the quiery which in this case is Gallet.
This is great information, thank you. New to this forum.
Looks like Landeron 48 caliber or 149.
https://www.google.com/amp/s/reference.grail-watch.com/family/landeron-48/amp/
After the chronograph starts, what button do you use to stop it? If the 4 o clock reset, then it's a 48. It the 2 oclock, the 149. It's likely a 149 as Gallet used those.
Watch looks like a 45 clamshell. I have a gold Gallet with the same ridiculously small pusher caps, so it looks correct.
As for price, it is worth more based on cindition, as you know. It's difficult to tell much based on these photos, as the detail is obscured.
The gold is nice, but surprisingly not always more desired than steel. The movement is not as desired as the other movements used by Gallet, such as Excelsior Park or Valjoux. My gut says ball park USD 3500 to 4500.
Search for watches with similar movements and condition to narrow down the value.
Can you tell us more about this? Are you thinking of buying it, or do you now own it? What do you know about its history? Are you a fan of Gallet?
i have someone that wants to sell but they have been doing their own research and believe it has a value of 25,000. Wanted to be able to show them otherwise. Thank you for you help.
Landeron based watches tend to be in the 350 to 2200 depending on condition. Parts watches can be as little as 120 to 160. Again check sold listing. Not someones fantasy figures.
Valjoux movement based watches can be a bit more. Mostly for the movement as the parts can be used to repair or franken Rolex watches. Rolex operates within it's own rule book.
Curiously I have purchased some cheap scrap chrono cases. They do not fit my landeron movements. They do however fit a valjoux. Probably because someone scrapped the case for the movement.
Gold watches are worth melt value.
These things were produced in the millions.
Generally, you ahould not even respond to anyone who is that crazy. But I am curious to know what kindof fantasies are floating around in their head to make them think this is worth 25k. It's best to just walk away.
Realistic ballpark value of $3k USD, IMO ... speaking very roughly. Gallet chronographs are collectible, but they're not super high end, and the 14k gold and Landeron movement in this one make it a mid-tier example.
Does not appear to have a clamshell case in those photos, @pdxleaf, which would increase the value. And no Brevet in case-back.
In what currency does the seller think it is worth 25,000? That person is living in another universe, you will never make a deal. 馃え
