Condensation in Speedmaster
Good to hear the second boutique is taking care of it all, I guess that should be the one you stick to in the future as the advice the first one gave certainly made no sense.
Pretty obvious that one of the gaskets has failed. If a boutique said washing your hands while the chrono is running could cause this they are incompetent. Omega gave you bad data when they said the seals were good, they aren't. And why didn't the first boutique take it in under warranty, instead just sending you on your way? In my experience most people working in the boutiques have minimal knowledge about their watches, or worse, just make nonsense up, like they did with you.
Since you mentioned you are in Southern California, I'd be interested to learn which two boutiques are involved, so I can avoid the first one...
And it's amazing (in a bad way) that people still repeat the nonsense about 5 atmosphere water resistance being insufficient for washing your hands.
Where are these people sprouting this nonsense about the 5 atmosphere water resistance being insufficient for washing your hands?
I believe it's sufficient when the watch is in perfect condition.
It's just that with time and daily life, that water resistance rating becomes meaningless in an ever diminishing fashion until it potentially becomes near impossible for a reputable watchmaker of any persuasion to guarantee that 5 atmosphere water resistance to hold for the period between services, even following a fresh service.
Even for a like new watch, should it be damaged in some manner which is not necessarily apparent by casual inspection, it may have compromised water resistance.
This is a fact of life unless the watch is looked after to the highest standard.
All these watches are water resistant up to a point, until they are not.
But at the very least, wouldn’t this be tested by a reputable watchmaker as part of a complete service, and wouldn’t following that be the exact period where one could have confidence in the water resistance rating? I mean, there must be some period of time where this holds true, right?
See, that's the thing with it.
What is a reasonable period?
I'm sure most of us would agree that the full period between services would be reasonable, generally speaking.
However there are so many variables, such as how long between services as an example baseline?
Then the consensus within the industry is that a dive watch used for it's intended purpose should be pressure tested every year as best practice while some divers may opt for every 2 years.
The risk has to be managed by the owner as they see fit.
If the seals were replaced, and there's no subsequent damage, then yes that period would be of very high confidence.
I always remind people that most companies recommend pressure testing periodically - Omega recommends this at least once per year, preferably right before the season when you are most likely to take the watch swimming.
